Clarify next-hop-self in RR
Ethan55
I have a simple topo as below:
R9 and R13 establish iBGP with RR. R9 is RR client of RR (10.10.10.10). R13 is a normal iBGP neighbor of RR.
I use OSPF and LDP.
R9 and R13 have VRF VPNA and exchange Lo1 as the VPNv4 route. Do Next-hop self in RR.
R13 and R9 learn the VPNv4 route of each other but can not ping each other.
R9#show ip route vrf VPN_A
Routing Table: VPN_A
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
C        172.16.167.0/24 is directly connected, Loopback1
L        172.16.167.1/32 is directly connected, Loopback1
B        172.16.168.0/24 [200/0] via 10.10.10.10, 00:30:41
R13#show ip route vrf VPN_A
B        172.16.167.0/24 [200/0] via 10.10.10.10, 00:31:55
C        172.16.168.0/24 is directly connected, Loopback1
L        172.16.168.1/32 is directly connected, Loopback1
ICMP request out but was dropped at RR. The current configuration:
R13
vrf definition VPN_A
 rd 13.13.13.13:1
 route-target export 999:1
 route-target import 999:1
 address-family ipv4
 exit-address-family
interface Loopback0
 ip address 13.13.13.13 255.255.255.255
interface Loopback1
 vrf forwarding VPN_A
 ip address 172.16.168.1 255.255.255.0
router ospf 1
 network 13.13.13.13 0.0.0.0 area 0
 network 192.168.23.0 0.0.0.255 area 0
router bgp 7552
 bgp log-neighbor-changes
 neighbor 10.10.10.10 remote-as 7552
 neighbor 10.10.10.10 update-source Loopback0
 address-family ipv4
  neighbor 10.10.10.10 activate
 exit-address-family
 address-family vpnv4
  neighbor 10.10.10.10 send-community extended
 exit-address-family
 address-family ipv4 vrf VPN_A
  redistribute connected
 exit-address-family
R9
 rd 9.9.9.9:1
 address-family ipv4
 exit-address-family
interface Loopback0
 ip address 9.9.9.9 255.255.255.255
interface Loopback1
 ip address 172.16.167.1 255.255.255.0
router ospf 1
 network 9.9.9.9 0.0.0.0 area 0
 network 192.168.29.0 0.0.0.255 area 0
router bgp 7552
 address-family ipv4
 exit-address-family
 exit-address-family
 exit-address-family
RR
router bgp 7552
 bgp router-id 10.10.10.10
 address-family ipv4 unicast
 address-family vpnv4 unicast
 neighbor 9.9.9.9
  remote-as 7552
   route-reflector-client
   next-hop-self
   soft-reconfiguration inbound always
   next-hop-self
 neighbor 13.13.13.13
  remote-as 7552
   next-hop-self
  next-hop-self
If I don't Next-hop self in RR, I can ping between VPNA of R13 and R9 successfully. Please help me clarify this case.
Thanks.
Hi ,
I see the next hop has been changed by the RR. This is an uncommon design and I had never tested it before, but it appears that the RR stitches the two LSP (R13 to RR and RR to R9). So yes, it should work after all. Thanks for testing it @MHM Cisco World .
I ran a quick test with XR (7.1.1) and it worked as well.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
37 Replies 37
M02@rt37
Hello @Ethan55,
R9 is advertising its connected routes for VRF VPN_A to the RR (neighbor 9.9.9.9) through BGP redistribution. The RR reflects these routes to R13, and since R13 has a direct BGP peering session with R9, it has a valid route to reach the next-hop IP 9.9.9.9 (R9's Loopback0).
In this specific setup, even without the "next-hop-self" configuration on the RR (neighbor 9.9.9.9), the ping between the VPN-A interfaces of R13 and R9 might still work correctly. The reason for this is that the RR is only reflecting the routes from R9 to R13, but R13 still learns the routes directly from R9 through the direct BGP peering session.
Your use case:
--R9 advertises its connected route for VRF VPN_A to the RR (neighbor 9.9.9.9) through BGP redistribution.
--The RR receives the connected route from R9 for VRF VPN_A. The route includes the next-hop IP address of R9's Loopback0 (9.9.9.9).
--The RR reflects the received route to R13.
--R13 receives the reflected route with the next-hop IP address as 9.9.9.9. Now, R13 has an IP route pointing to 9.9.9.9 for VRF VPN_A's network through the RR.
--However, R13 also has a direct BGP peering session with R9, and it has already learned the connected route for VRF VPN_A from R9 directly.
--When R13 needs to forward traffic to the VPN-A network of R9, it will prefer the directly learned route via the direct BGP peering session because it has a lower administrative distance than the route received from the RR.
Due to this behavior, the "next-hop-self" configuration might not significantly impact the successful ping between the VPN-A interfaces of R13 and R9. R13 will prioritize the directly learned route via the BGP peering with R9 over the reflected route via the RR.
In a different scenario where there is no direct BGP peering between R9 and R13, the "next-hop-self" configuration on the RR might become crucial to ensure reachability to R9's VPN-A network. In such cases, the RR would need to manipulate the next-hop so that it becomes reachable for R13 and other BGP clients.
Best regards
Hi M02@rt37 ,
R9 and R13 are not peering BGP directly.
R9 and R13 have BGP with RR.
R9 is RR client of RR.
R13 is a normal iBGP neighbor.
Harold Ritter
Hi @Ethan55 ,
You can't change the next hop for the VPNv4 routes, as this breaks the end to end LSP. What is it that you are trying to achieve?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @Harold Ritter ,
With the same setup, I see it working normally with IPv4 routes.
I mean if R9 and R13 advertise IPv4 route via BGP and Next-hop self in RR, R9 and R13 can ping IPv4 route of each other successfully.
Hi @Ethan55 ,
The IPv4 setup is different as it does not rely on an end to end LSP. Nevertheless, I made a quick test and see that the RR should stitch the 2 LSP (R13 to RR and RR to R9). It worked for me with XRv 7.1.1. What version do you run on the RR in your lab?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
address-family ipv4
 exit-address-family
The next hop self is by defualt add for vpnv4 for PE to PE
The issue you have you actvie ipv4 and vpnv4 for same neighbor' this I think issue you need to activate only vpnv4
All other config is correct.
Check RR it must run mpls also. If not the traffic will drop.
if above not solve issue then
the secret weapon command ...LOL
retain route-target all
what this command is, the RR have not VRF config so it can pass VPNv4 update but not data traffic between VRF (route not inject into RIB) so we use above command to solve this issue
Hi @MHM Cisco World ,
The issue is the next hop self on the RR. This is what breaks the end to end LSP between the two PEs.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
RR can config as next hop self of vpnv4' but it recommends to not do that.
He ask why when next hop self config in RR the traffic drop
And I answe him
Check mpls label
And need command above because of missing vrf in RR.
The RR retains all VPNv4 routes by default. The command "retain route-target all" is not needed. This command is normally used on an ASBR.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Let him add it and check' I know it for inter-as mpls but why we need it?
It is pretty clear from the original post that the issue happens when the OP configures next-hop-self on the RR. No need to try additional commands. The OP was just asking why setting next-hop-self on the RR breaks connectivity between R9 and R13. We already responded to that.
The command is needed on an ASBR because the routes are not retained by default if RT does not match a local RT import.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Do you want from me do lab and check ?
You can lab it if you want, but we already know what the issue is. Changing the next hop on the RR breaks end to end LSP.
Here's from the OP:
"If I don't Next-hop self in RR, I can ping between VPNA of R13 and R9 successfully. Please help me clarify this case."
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
