Clarify next-hop-self in RR
Ethan55
I have a simple topo as below:
R9 and R13 establish iBGP with RR. R9 is RR client of RR (10.10.10.10). R13 is a normal iBGP neighbor of RR.
I use OSPF and LDP.
R9 and R13 have VRF VPNA and exchange Lo1 as the VPNv4 route. Do Next-hop self in RR.
R13 and R9 learn the VPNv4 route of each other but can not ping each other.
R9#show ip route vrf VPN_A
Routing Table: VPN_A
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
C        172.16.167.0/24 is directly connected, Loopback1
L        172.16.167.1/32 is directly connected, Loopback1
B        172.16.168.0/24 [200/0] via 10.10.10.10, 00:30:41
R13#show ip route vrf VPN_A
B        172.16.167.0/24 [200/0] via 10.10.10.10, 00:31:55
C        172.16.168.0/24 is directly connected, Loopback1
L        172.16.168.1/32 is directly connected, Loopback1
ICMP request out but was dropped at RR. The current configuration:
R13
vrf definition VPN_A
 rd 13.13.13.13:1
 route-target export 999:1
 route-target import 999:1
 address-family ipv4
 exit-address-family
interface Loopback0
 ip address 13.13.13.13 255.255.255.255
interface Loopback1
 vrf forwarding VPN_A
 ip address 172.16.168.1 255.255.255.0
router ospf 1
 network 13.13.13.13 0.0.0.0 area 0
 network 192.168.23.0 0.0.0.255 area 0
router bgp 7552
 bgp log-neighbor-changes
 neighbor 10.10.10.10 remote-as 7552
 neighbor 10.10.10.10 update-source Loopback0
 address-family ipv4
  neighbor 10.10.10.10 activate
 exit-address-family
 address-family vpnv4
  neighbor 10.10.10.10 send-community extended
 exit-address-family
 address-family ipv4 vrf VPN_A
  redistribute connected
 exit-address-family
R9
 rd 9.9.9.9:1
 address-family ipv4
 exit-address-family
interface Loopback0
 ip address 9.9.9.9 255.255.255.255
interface Loopback1
 ip address 172.16.167.1 255.255.255.0
router ospf 1
 network 9.9.9.9 0.0.0.0 area 0
 network 192.168.29.0 0.0.0.255 area 0
router bgp 7552
 address-family ipv4
 exit-address-family
 exit-address-family
 exit-address-family
RR
router bgp 7552
 bgp router-id 10.10.10.10
 address-family ipv4 unicast
 address-family vpnv4 unicast
 neighbor 9.9.9.9
  remote-as 7552
   route-reflector-client
   next-hop-self
   soft-reconfiguration inbound always
   next-hop-self
 neighbor 13.13.13.13
  remote-as 7552
   next-hop-self
  next-hop-self
If I don't Next-hop self in RR, I can ping between VPNA of R13 and R9 successfully. Please help me clarify this case.
Thanks.
37 Replies 37
Hi @MHM Cisco World
"The next hop self is by defualt add for vpnv4 for PE to PE"
--> I don't think so, NHS is not by default. If I don't set NHS in RR, R9 will learn R13's VPNv4 route with Next-hop 13.13.13.13 and R13 will learn R9's VPNv4 route with Next-hop 9.9.9.9. And in this case, R9 and R13 can ping the VPNv4 route of each other successfully.
To clarify That why I mention PE-to-PE
In ipv4 bgp if fwo routers connect via iBGP by default the next-hop-self is disable
In vpnv4 bgp (without RR) if two routers ibgp the next-hop-self is enabled by defualt.
The issue you have you active ipv4 and vpnv4 for the same neighbor' this I think issue you need to activate only vpnv4.
--> Also do your suggestion but no luck.
the IOU2 is RR and I config next-hop-self all and the ping is success NO ISSUE at all
sorry I have IOS and IOS XE only but the principle is same
do show ip bgp vpnv4 all <<- in RR and check the route is add to correct VRF or not
THANKS
MHM
Hi @MHM Cisco World ,
The principle is not the same. In IOS and IOS-XE, you need to configure the "all" keyword on the next-hop-self command for it to apply to both iBGP and eBGP learnt prefixes. By default, it only changes the next to self for the eBGP learnt prefixes.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
I know we need all
I am talking about principle of RR with next-hop-self in mpls
Hi ,
I see the next hop has been changed by the RR. This is an uncommon design and I had never tested it before, but it appears that the RR stitches the two LSP (R13 to RR and RR to R9). So yes, it should work after all. Thanks for testing it @MHM Cisco World .
I ran a quick test with XR (7.1.1) and it worked as well.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks alot for all your support' I every day learn new from your experiences.
Thanks again
Have a nice summer
MHM
Hi @MHM Cisco World
Still not yet to get your idea to fix my case.
Hi @Harold Ritter ,
--> How it can work, can you point me what is wrong in my set up.
Thanks.
Share show ip bgp vpnv4 in RR
Hi @Ethan55 ,
Let's put it that way, it is not a common scenario. You normally would want the connectivity to be end to end between the two PEs without being forced through the RR. I ran a quick test though and see that the RR will perform the VPNv4 label swapping and forward traffic to the egress PEs (R9 and R13). The above mentioned behavior is caused by the RR forcing the next hop self on VPNv4 prefixes learnt from the PEs.
It would help if you could post the full config for the RR so we can understand why it is not working in your case.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @Ethan55 ,
Please provide the full configuration for the RR so we can help determine what is wrong with your setup.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @Harold Ritter ,
Full config:
R9 (e0/0) ---- (gi0/0/0/7) RR (gi0/0/0/6) ---- (e0/0) R13
R9
R9#show running-config
Building configuration...
Current configuration : 2576 bytes
! Last configuration change at 16:46:45 +07 Sun Jul 16 2023 by juniper
version 15.5
hostname R9
boot-start-marker
boot-end-marker
rd 9.9.9.9:1
address-family ipv4
exit-address-family
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone +07 7 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip domain name VIETTEL
ip cef
no ipv6 cef
mpls label protocol ldp
cts logging verbose
username juniper privilege 15 secret 5 $1$thTq$utqTIVaDCRFo8m.pPw82a/
username namnh privilege 15 secret 5 $1$NYtf$Sh1Cnof/jNQ1B9Yd1DSoz/
redundancy
no cdp log mismatch duplex
ip tcp synwait-time 5
interface Loopback0
interface Loopback1
interface Ethernet0/0
ip address 192.168.29.9 255.255.255.0
ip ospf network point-to-point
ip ospf cost 1000
mpls ip
interface Ethernet0/1
no ip address
interface Ethernet0/1.2000
encapsulation dot1Q 2000
ip address 172.16.124.1 255.255.255.252
interface Ethernet0/2
no ip address
interface Ethernet0/3
description TO_MGMT
ip address 10.99.89.12 255.252.0.0
router ospf 2000 vrf VPN_A
area 2000 nssa default-information-originate no-summary
network 0.0.0.0 255.255.255.255 area 2000
router ospf 1
router bgp 7552
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.0.0.0 255.0.0.0 10.96.0.1
mpls ldp router-id Loopback0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login local
transport input ssh
end
R13
R13#show running-config
Current configuration : 1892 bytes
! Last configuration change at 16:56:08 +07 Sun Jul 16 2023
version 15.5
hostname R13
boot-start-marker
boot-end-marker
rd 13.13.13.13:1
address-family ipv4
exit-address-family
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Loopback1
ip address 192.168.23.13 255.255.255.0
ip ospf cost 1000
mpls ip
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router ospf 1
router bgp 7552
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input none
end
RR
!! IOS XR Configuration 6.1.3
!! Last configuration change at Wed Jul 19 22:59:09 2023 by namnh
hostname CKV01
domain name VIETTEL
vrf TEST
import route-target
100:438
999:1
export route-target
100:438
999:1
line default
transport input ssh
control-plane
management-plane
out-of-band
interface MgmtEth0/0/CPU0/0
allow SSH peer
address ipv4 10.0.0.0/8
interface Loopback0
ipv4 address 10.10.10.10 255.255.255.255
ipv4 address 10.99.89.13 255.252.0.0
interface GigabitEthernet0/0/0/0
ipv4 address 192.168.16.10 255.255.255.0
interface GigabitEthernet0/0/0/1
ipv4 address 192.168.19.10 255.255.255.0
interface GigabitEthernet0/0/0/2
ipv4 address 192.168.28.10 255.255.255.0
interface GigabitEthernet0/0/0/3
ipv4 address 192.168.27.10 255.255.255.0
interface GigabitEthernet0/0/0/4.1
ipv4 address 192.168.21.13 255.255.255.0
encapsulation dot1q 1
interface GigabitEthernet0/0/0/5
vrf TEST
ipv4 address 10.4.30.1 255.255.255.0
interface GigabitEthernet0/0/0/6
ipv4 address 192.168.23.10 255.255.255.0
interface GigabitEthernet0/0/0/7
ipv4 address 192.168.29.10 255.255.255.0
interface GigabitEthernet0/0/0/8
shutdown
interface GigabitEthernet0/0/0/9
shutdown
interface GigabitEthernet0/0/0/10
shutdown
interface GigabitEthernet0/0/0/11
shutdown
interface GigabitEthernet0/0/0/12
shutdown
interface GigabitEthernet0/0/0/13
shutdown
interface GigabitEthernet0/0/0/14
shutdown
route-policy PASS
pass
end-policy
router static
10.0.0.0/8 10.96.0.1
router ospf 1
area 0
interface Loopback0
passive enable
cost 2000
cost 1000
cost 50
cost 2000
cost 1000
cost 1000
router bgp 7552
neighbor 9.9.9.9
remote-as 7552
next-hop-self
remote-as 7552
next-hop-self
vrf TEST
rd 100:438
label mode per-prefix
mpls oam
mpls ldp
ssh server v2
end
Hi @Ethan55 ,
I do not see anything in the RR configuration that would prevent R13 from pinging R9 a vice versa, except  for the version you are currently running (6.1.3). Could you load something more recent, at least 6.3.1 and try again.
After upgrading, you will have to add the following command for the RR to change the next hop on iBGP learnt routes, as it doesn't happen by default:
RR:
router bgp 7552
 ibgp policy out enforce-modifications
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
