communication between two VRFs
anil.kumar1
Community Member
Hi All,
I have two customers ( A & B). A is parent and B is child of A but both are on different VRFs . Now Parent A wants to communicate its child B.
is there any possibility?
Since i am new to MPLS so this is just a query that came into my mind. Would really appreciate for any answers.
Anil
Mark Malone
Yes you do vrf leaking between the 2 vrfs so they can speak to each other and see each others routes
This doc explains it with examples
http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/multiprotocol-label-switching-vpns-mpls-vpns/47807-routeleaking.html
magohil
Visitor
Hi Anil,
Assume it is simple form of Hub and Spoke topology.
Vrf A want to communicate with vrf B and same way reverse too.
You may play with rt values. It is very simple to understand: One vrf export prefix with certain tag and another vrf import same tag. Same way for child vrf as well.
vrf A
rd 100:100
export 1:1
import 1:2
vrf B
rd 200:200
export 1:2
import 1:1
Since these are two different customer you may not want to leak all prefix, if so you may play with export / import map , keeping tight control on what prefix from what vrf you want to allow.
Mahesh
