Configuration conversion tool for huawei to cisco
ciscoyogi
Looking for automated tool for converting Huawei router/switches configurations to cisco router/switches.
7 Replies 7
ammahend
I don't think there is one, you will have to do it manually.
-hope this helps-
Hi Ammahend,
I suppose that is the only way left.
Hi Flavio,
Thanks for your reply,
I am looking for Huawei to Cisco translation
But the idea is the same. If they have this tool to translate from Huawei to Cisco you just need to reverse engineer the command.
did you have the link to download, I see the documentation and the huawei page to download but i dont find it.
This tool is available only for Huawei-certified engineers or partners. not for cisco certified engineers.
