DHCP Relay Problem at Multicast VRF
jakskal07
I'm creating DHCP server at 7200, and creating DHCP relay at my 7609 to distribute IP address for multicast VRF. DHCP server is work at my local 7200, but seems the relay is not working. The config is like this:
7200:
ip dhcp pool Test-1
vrf Multicast_VRF
network 192.168.6.0 255.255.255.0
default-router 192.168.6.1
ip vrf Multicast_VRF
rd 1:15000
route-target export 1:15000
route-target import 1:15000
mdt default 239.232.0.1
mdt data 239.232.1.0 0.0.0.255 threshold 1
mdt log-reuse
7609:
interface Port-channel1.301
encapsulation dot1Q 301
ip dhcp relay information trusted
ip vrf forwarding Multicast_VRF
ip address 1.2.4.1 255.255.255.0
ip helper-address 192.168.6.1
ip flow ingress
ip flow egress
ip pim sparse-mode
Please help me regarding this :) Thx.
Reza
cpubob
I don't see that you have an interface on your 7200 in the vrf Multicast_VRF. If you set one of your remote boxes to static, can it ping 192.168.6.1? On your 7200, have you attempted to debug ip traffic or dhcp traffic for the vrf? Are you seeing dhcp requests on the 7200?
