Disabling split horizon for H-VPLS on 7609
Jacob.chu
We installed a new 7609 in our lab for doing H-VPLS interop. The sw Version is IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD7.
I do not see the "no-split-horizon" option when trying to configure the remote spoke PE.
l2 vfi PE3-VPLS-A manual
vpn id 200
neighbor 20.0.0.1 encapsulation mpls <no-split-horizon>
Is there a version problem or some config issue ?
AT
Jacob.chu
The hw info is as follows :-
Mod Ports Card Type Model Serial No.
1 2 2+4 port GE-WAN OSM-2+4GE-WAN+ JAB0847061N
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAL0919113H
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3BXL SAL09253GNF 1.6 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL09190TCD 2.5 Ok
Harold Ritter
This option was introduced in 12.2(18)SXE and is therefore not present in the version you are currently running.
Hope this helps,
I loaded 12.2(18)SXF4, and the option is there now.
Thank you!
We have the following card installed in the Cisco 7609 :-
OSM-2+4GE-WAN
I do not see the "switchport" commands on the 4 WAN ports ? Is this normal ? How do I enable VLANs plus STP on the 4 WAN ports ?
I only see the "switchport" commands on the first 2 LAN ports.
IOS 12.2(18)SXF4
