EOMPLS QOS help needed
ahsanrasheed1
Community Member
Any one can guide me how to make qos in EOMPLS L2VPN. After making tunnel between two client end devices how to make QOS between each other bidirectional.how to make qos in core of mpls backbone with uniform mode. i also want the configs if possible. I think any core service provider engineer can better help me.
CE1------>PE1------>P------->PE2------->CE2(how to make qos from ce1 to ce2 and also core of mpls backbone.
Specifically i am having problem in mapping the layer 2 qos to layer 3 qos(cos to dscp and dscp to exp mapping). how to do qos mapping on CE and PE.
how to apply qos mapping on CE and PEspecifically with cos.
Waiting for replies.
11 Replies 11
Sandip Rathod
Hi Rasheed,
The default behavior for the EoMPLS is to use a value of “0” in the EXP bits of the VC and tunnel labels. Ingress packet classification can be COS or DSCP/Prec. Default behavior can be changed by using “set mpls experimental imposition ” at ingress
On the PE, you need to match packet with classification and mark it with MPLS EXP bit value, and on egress side, mark with original value.
There is a section for EoMPLS QoS on below document, you may need to go through it for detailed understanding
http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_25_seg_seg1/configuration/guide/swmpls.pdf
Sandip
Hi Sandip,
First of all i would like to say thanks for you reply and help. Really appreciated.
I also would like to request all cisco members to kiindly guide me on this case. I am stuck on this qos issue of eompls. Requesting to all CCIE's, kindly guide me.
Sandip, i have already checked with the things you mentioned.
I have already checked with below commands on PE with classification of cos for port based eompls
On PE:
int fastEthernet 0/0
no ip address
xconnect 5.5.5.5 100 encapsulation mpls
service-policy input foo
no shutdown
Class-map cos
match cos 5
Policy-map foo
class cos
set mpls experimental imposition 5
Because PE router will get frame not IP packet. we need to match cos but ccos is not working on PE router.I am uanble to see traffic with cos5, just see traffic value of 0 with EXP.
I am getting error, you can match cos on this interface.
any conversion needed for cos to exp or cos to dscp or dscp to exp ?
Also any need to enable qos globally with mls qos or mls qos trust cos on interface of customer facing port. any need to configure port of client port also for msl qos trust cos.Also 3725 routers not supported mls qos trust cos or mls qos  or mls qos trust.Need some high end routers. I have also checked with 6503 classification of cos is also not working.
Also which routers i can check with. mean ios.
waiting for replies.
Hi Sandeep & all other members,
Kindly reply me and guide me how to fix this issue.
Replies will be appreciated.
Hi Ahsan,
Match CoS to QoS and then QoS to Exp bits.
Sandip
Hi Sandeep,
Thanks for reply. Can you elaborate your answer in detail with some example. Because i have already checked cos to exp mapping on PE and its not working. I only see traffic in class-default mean with 0 exp which is by default behaviour.
On PE:
no ip address
no shutdown
Class-map cos
match cos 5
Policy-map foo
class cos
Hi Sandeep,
I have used this scenario. kindly check it below. Using 5 routers. CE1(router with sub int dot1q), PE1(router), P(router), PE2(router), CE2(router with sub int Dot1q). i have made policy and classification of ip dscp on PE routers but see only class-default traffic not with exp 5 or dscp ef. is there any mistake on config or any changes need to be made.
CE1--->PE1---->P------>PE2------->CE2
PE1#show policy-map interface
FastEthernet0/0
  Service-policy output: mpls_exp
    Class-map: exp (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: mpls experimental topmost 5
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 30 (%)
        Bandwidth 2250 (kbps) Burst 56250 (Bytes)
        (pkts matched/bytes matched) 0/0
        (total drops/bytes drops) 0/0
    Class-map: class-default (match-any)
      3880 packets, 322434 bytes
      Match: any
FastEthernet0/1.455
  Service-policy input: foo
    Class-map: dscp (match-all)
      0 packets, 0 bytes
      Match: ip dscp ef (46)
      QoS Set
          Packets marked 0
      48 packets, 5745 bytes
      Match: any
PE1(configuration):
class-map match-all dscp
match ip dscp ef
class-map match-all exp
match mpls experimental topmost 5
policy-map mpls_exp
class exp
  priority percent 30
policy-map foo
class dscp
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
ip address 192.168.23.2 255.255.255.0
ip ospf network point-to-point
duplex auto
speed auto
mpls ip
service-policy output mpls_exp
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.455
encapsulation dot1Q 455
xconnect 5.5.5.5 455 encapsulation mpls
router ospf 1
log-adjacency-changes
network 3.3.3.3 0.0.0.0 area 0
network 192.168.23.2 0.0.0.0 area 0
CE1 ping to CE2:
R10#p
Protocol [ip]:
Target IP address: 172.16.15.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 172.16.15.1
Type of service [0]: 0xb8
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 172.16.15.2, timeout is 2 seconds:
Packet sent with a source address of 172.16.15.1
Hi Ahsan,
1) Make sure you are sending traffic from CE with DSCP EF, Can you also post output for the same
2) Can you try with removing "service-policy input foo" from subinterface to main interface - Fa0/0/1
3) mls qos is enabled ?
Which image are you using on PE1 router ?
Sandip
Hi Sandeep,
I really appreciated your help and i am really thankful of you. I am stuck on two things. can you guys can guide me how to solve this issue, need to correct any config on PE2 or PE1.
CE1---->PE1------->P-------->PE2--------->CE2(all four router i am using with image
3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7. not using mls qos command because not supported on this ios.
1)I am unable to see any traffic on PE2 router on output interface although i can see traffic on input interface of PE2 router.this is the major issue of not seeing traffic on output interface.
2)After configuring PE2 configuration of qos, I am unable to see traffic on PE1 output interface although i can see traffic on input interface.
Kindly guide me how to fix these two issues.
PE2 config:
class-map match-all EXP_5
class-map match-all QOS_GROUP_5
match qos-group 5
policy-map mpls2ip
class QOS_GROUP_5
  set cos 5
policy-map IN_FROM_R4
class EXP_5
  set qos-group 5
interface FastEthernet0/0.455
xconnect 3.3.3.3 455 encapsulation mpls
service-policy output mpls2ip
interface FastEthernet1/0
ip address 192.168.34.4 255.255.255.0
duplex auto
speed auto
mpls ip
service-policy input IN_FROM_R4
PE2#show policy-map interface
FastEthernet0/0.455
  Service-policy output: mpls2ip
    Class-map: QOS_GROUP_5 (match-all)
      0 packets, 0 bytes
      Match: qos-group 5
      QoS Set
        cos 5
          Packets marked 0
      0 packets, 0 bytes
      Match: any
FastEthernet1/0
  Service-policy input: IN_FROM_R4
    Class-map: EXP_5 (match-all)
      5 packets, 700 bytes
      QoS Set
        qos-group 5
          Packets marked 5
      355 packets, 28066 bytes
      Match: any
PE2#
PE1 config:
class-map match-all QOS_G_5
match qos-group 5
class-map match-any cos3
match cos  3
class-map match-all qos3
match qos-group 3
class-map match-any LOO1
match cos  5
policy-map EF
class LOO1
  set qos-group 5
policy-map QOS_G_5
class QOS_G_5
  set mpls experimental topmost 5
duplex auto
speed auto
mpls ip
service-policy output QOS_G_5
no ip address
duplex auto
speed auto
service-policy input EF
FastEthernet0/0
  Service-policy output: QOS_G_5
    Class-map: QOS_G_5 (match-all)
      0 packets, 0 bytes
      Match: qos-group 5
      QoS Set
          Packets marked 0
      10 packets, 1386 bytes
      Match: any
FastEthernet0/1.455
  Service-policy input: EF
    Class-map: LOO1 (match-any)
      9 packets, 1062 bytes
      Match: cos  5
        5 minute rate 0 bps
      4 packets, 256 bytes
      Match: any
CE1 config:
class-map match-all EF
match access-group 1
policy-map EF
class EF
  set cos 5
ip address 172.16.15.1 255.255.255.0
service-policy output EF
access-list 1 permit 172.16.15.1
CE1# show policy-map interface
FastEthernet0/0.455
  Service-policy output: EF
    Class-map: EF (match-all)
      Match: access-group 1
      QoS Set
        cos 5
          Packets marked 9
      Match: any
CE1#
Anyone cisco enginner or ccie engineer can guide me on this issue.
Waiting for replies. Replies will be appreciated.
Hi Rasheed,
Sorry for delay as yesterday occuiped with lots of stuff.
First on PE1, I do not see any QoS action set on output policy-map, can you please check this ?
Match: cos 5
5 minute rate 0 bps
On PE2 output policy you don;t see any traffic match.
If there is no traffic match on QOS_GROUP_5, atleast we should see traffic match on class-default. or if its dropped, we should see match against drop, but we don;t see any packet match against any classe on PE2 output policy
Do you see traffic coming on PE2 output interface ?
0 packets, 0 bytes
Match: qos-group 5
QoS Set
cos 5
Packets marked 0
0 packets, 0 bytes
Match: any
From configuration persective it looks, ok, I would suggest check step by step on each interface
1) Traffic on CE1 output interface, it's matching against cos 5, working perfectly
2) Match cos5 and set qos on PE1 intput interface
3) match qos and set mpls on PE1 output interface
4) match mpls and set qos on PE2 input interface
5) match qos and set cos on PE2 output interface
And vice versa for reverse traffic, if you still face issue I would suggest to raise TAC case, there might be some BUG
Sandip
Hi Sandeep,
Thanks for your reply. i really appreciated.Can you or other guys guide me i am stuck in one major issue.
you know i was using this topology in eompls qos CE1(2811router)------->PE1(2811router)--------->P(2811router)---------->PE2(2811router)--------->CE2(2811router).When i am using this topology i can see and mark the traffic on each router.
when i am using this topology(CE1(2811router)------->PE1(2811router)--------->P(6523 layer3 switch)---------->PE2(2811router)-------------->CE2(2811router)with 6523 layer3 switch i am unable to see any traffic mark with exp5 or exp, see traffic on class-default with exp0.
0n 6523 switch config:
class-map exp5
policy-map foo
class exp5
int gi1/1
ip 192.168.23.3
mpls ip
mtu 1546
service-policy output foo
int gi1/2
ip 192.168.34.4
mpls ip
mtu 1546
i can see traffic marked on ce1, pe1 but no traffic marked or seen on router P, PE2 and CE2.
I have triedon 6523 switch, mls qos command globally on 6523.also tried on interface trust command: mls qos trust cos , mls trust mpls exp topmost. but still no success.
Any additional configuration needed on 6523 switch?
