11-20-2004 10:32 AM
I would appreciate if you answer my following questions :
- As you know EoMPLS is based on physical port, but how about VPLS?
- Could you tell me minimum router which supports VPLS?
- Any other solutions for transfer ethernet frames over MPLS except VPLS and EoMPLS?
- I think VPLS is better EoMPLS because it supports multipoint to multipoint ,is it true? could you please tell me VPLS advantage and disadvatage?
M.Arshad rad
11-22-2004 06:42 AM
Ehlo ,
1)EoMPLS is available in port and vlan mode.Since VPLS
is actually using martini encapsulations ( both lasserre and kompella ) it is possible to use raw and tagged modes.
2)IMHO only Cisco router that supports VPLS now is 7600.Additionaly VFI can be only assigned to SVI.
3)Juniper CCC ( RSVP based ) - but obviously you won't use it since it's proprietary ( nevertherless it has nice feature like lsp-stiching ) and IOS couldn't signall it .
4) VPLS is designed to support p-to-mp and therefore
it's more complex.IF you don't need its features you can stick with raw p2p martini , which is relatively simple and widely implemented ( no problem for example to configure it between ios and junos boxes ).
pm
11-22-2004 09:40 AM
Thank you for your reply.
As you said EoMPLS is available in vlan mode so i can tag my ethernet customers before MPLS cloud then PE router separate them by logical interface based on vlan, does it true?
i want to know about port density in MPLS network so i would appreciate if you explain me about this situation.for instance if i have 50 customers then should i have 50 ports in my MPLS cloud (PE routers) or i can aggrigate them by layer2 802.1Q switchs before PE routers then the PE routers connect to switch by trunk link.
Thank you,
M.Arshad Rad
11-23-2004 04:59 AM
Ehlo,
Yes , you can create 50 vlans and configure proper xconnect under subinterface.Cisco eompls is treating those vlan-id's on received frames as "service delimiting" thus tag are used to distinguish traffic ( eg circuit id's ).You don't have to install 50 eompls ports in order to terminate 50 diffrent customers.
However i don't have knowldege about maximum eompls port/pw/performance on diffrent Cisco platforms- maybe someone has some info on that topic
regards
Piotr Marecki
Netia S.A
