fast-reroute per-link priority-limit high level 1
zarni tun
I dig to know what means "fast-reroute per-link priority-limit high level 1" command.
It is under isis of address family ipv4 unicast.
I tried to read Cisco command guide, but really don`t know what its means.
Generally I know "fast-reroute per-link" portion. But what means "priority-limit high level 1" or "priority-limit high level 2" portion.
2 Accepted Solutions
Sunil Bhadauria
i will try to answer your query ,
if you know "fast-reroute per-link" , and how does it works then consider " fast-reroute per-link priority-limit high level 1" as more granular form of this command .
so lets take below few configuration example :
- Fast-reroute per-link priority-limit critical level 1
This will enable fast re-route LFA computation for level - 1 critical priority prefix only
- Fast-reroute per-link priority-limit high level 1
This will enable fast re-route LFA computation for level - 1 high and critical priority prefix only
Sunil Bhadauria
Kindly rate all helpfull posts
That is your isis level 1 and level 2 .
Sunil Bhadauria
Sunil Bhadauria
Sunil Bhadauria
Thanks Sunil.
How to classify level 1 and level 2?
Sunil Bhadauria
Ok.
Now I see.
Thanks Sunil.
