Flex-Algo label entries not being installed
Hi everyone,
I have the following flex-algo lab:
I have configured 3 flex algos on PE1 as follows:
router isis ISIS1
 is-type level-2-only
 net 49.0001.0100.0000.0001.00
 distribute link-state
 affinity-map RED bit-position 20
 affinity-map GREEN bit-position 10
 address-family ipv4 unicast
  metric-style wide
  advertise passive-only
  mpls traffic-eng level-2-only
  mpls traffic-eng router-id Loopback0
  segment-routing mpls sr-prefer
 address-family ipv6 unicast
  metric-style wide
  router-id Loopback0
  single-topology
 flex-algo 140
  priority 255
  advertise-definition
  affinity include-all GREEN
 flex-algo 150
  priority 255
  affinity include-all RED
 flex-algo 160
  priority 255
  affinity exclude-any GREEN
Assume the link colors on the interfaces match what is shown in the screenshot (so for example P1 has Gi0/0/0/0 and Gi0/0/0/2 are GREEN, Gi0/0/0/3 are RED and Gi0/0/0/4 is uncolored).
There are no other flex-aglo definitions advertised by any other router.
The SID indices are defined as follows:
 interface Loopback0
   prefix-sid index x
   prefix-sid algorithm 140 index 14x
   prefix-sid algorithm 150 index 15x
   prefix-sid algorithm 160 index 16x
   prefix-sid index 50x
   prefix-sid algorithm 140 index 54x
   prefix-sid algorithm 150 index 55x
   prefix-sid algorithm 160 index 56x
Where x is the node number (PE1 is node 1 etc - see diagram).
PE1 is configured to steer traffic with BGP Autosteering. Basically, SR polcies steer prefixes with ext-comm colors 40, 50 and 60 (and destination PE4 - 10.1.1.4) into flex-algos 140, 150 and 160 respectively.
All 3 policies come up with no issues. Given that PE4 is the destination, policies 40, 50 and 60 apply SID stacks of 16144, 16154 and 16164 respecitvely (SRGB 16000). I'm testing forwarding them using colored VPNv4 routes (not shown).
Here is an example:
RP/0/RP0/CPU0:PE1#show segment-routing traffic-eng policy color 50
Sat Jul 12 23:13:09.122 UTC
SR-TE policy database
Color: 50, End-point: 10.1.1.4
  Status:
    Admin: up  Operational: up for 00:23:34 (since Jul 12 22:49:34.514)
  Candidate-paths:
    Preference: 100 (configuration) (active)
      Requested BSID: dynamic
      Constraints:
        Prefix-SID Algorithm: 150
        Protection Type: protected-preferred
        Maximum SID Depth: 10
      Dynamic (valid)
        Metric Type: IGP,   Path Accumulated Metric: 50
          SID[0]: 16154 [Prefix-SID: 10.1.1.4, Algorithm: 150]
  Attributes:
    Binding SID: 24022
    Forward Class: Not Configured
    Steering labeled-services disabled: no
    Steering BGP disabled: no
    IPv6 caps enable: yes
    Invalidation drop enabled: no
    Max Install Standby Candidate Paths: 0
RP/0/RP0/CPU0:PE1#
Flex algo 140 and 160 work fine.
But flex-algo 150 is behaving weird.
It appears as though routers PE4, PE5, PE6, P1 and P2 are only installing some of the flex-algo indices:
RP/0/RP0/CPU0:PE6#show mpls forwarding | inc 1615
Sat Jul 12 23:03:47.993 UTC
16151  Pop         SR Pfx (idx 151)   Gi0/0/0/1    10.10.16.1      0
16155  Pop         SR Pfx (idx 155)   Gi0/0/0/0    10.10.56.5      0
16156  Aggregate   SR Pfx (idx 156)   default                      0
16157  Pop         SR Pfx (idx 157)   Gi0/0/0/3    10.10.67.7      0
RP/0/RP0/CPU0:PE6#
Most importantly they've not installed 16154. All the other routers install them ok:
RP/0/RP0/CPU0:PE1#show mpls forwarding | inc 1615
Sat Jul 12 23:16:25.030 UTC
16151  Aggregate   SR Pfx (idx 151)   default                      0
16152  16152       SR Pfx (idx 152)   Gi0/0/0/0    10.10.16.6      0
16153  16153       SR Pfx (idx 153)   Gi0/0/0/0    10.10.16.6      0
16154  16154       SR Pfx (idx 154)   Gi0/0/0/0    10.10.16.6      0
16155  16155       SR Pfx (idx 155)   Gi0/0/0/0    10.10.16.6      0
16156  Pop         SR Pfx (idx 156)   Gi0/0/0/0    10.10.16.6      0
16157  16157       SR Pfx (idx 157)   Gi0/0/0/0    10.10.16.6      0
16158  16158       SR Pfx (idx 158)   Gi0/0/0/0    10.10.16.6      0
24014  16154       SR TE: 3 [TE-INT]  Gi0/0/0/0    10.10.16.6      0
RP/0/RP0/CPU0:PE1#
Most notably 16154 is missing which is lable for PE4s flex-algo 150.
I'm not sure why this is the case. From a config point of view I can't find anything wrong.
All devices are a part of topology 150. For example, PE6 has no entries for Algo 140 (include-all GREEN) but that makes sense as it wouldn't be a part of that topology.
PE4 is definitely advertising it's flex-algo indices in its LSPs. I've tried debugging but can't seem to figure it out.
Does anyone have any ideas? (I can provide more information or configs if needed).
Network Engineer
CCIE SP #69245
So, I've managed to fix it simply by rebooting the nodes. I was running 7.9.2.
Not sure how that fixed it but will keep an eye on it.
Network Engineer
CCIE SP #69245
Harold Ritter
Hi @steven.crutchley ,
What XR version is this topology running? Can you please provide a "show runn router isis" from PE6?
Network Engineer
CCIE SP #69245
Thanks for the feedback @steven.crutchley
