GETVPN COOP Upgrade procedure
Hi Team,
Is there any particular procedure to upgrade Getvpn COOP servers,My setup is having both 3900 ISR at the same location acting as Primary and Secindary COOP.
My plan is the standard go for the secondary first and then for Primary.
DB
Jeff Orr
Level 5
Level 5
I just did this upgrade yesterday. Yes, you upgrade each secondary first (making sure COOP is active before moving to next one) and then finally hit primary. Since we like to have the primary be at our primary DC, we rebooted the now primary so that a reelection would occur.
GETVPN IOS Upgrade Procedure
This Cisco IOS upgrade procedure should be followed when a Cisco IOS code upgrade needs to be performed in a GETVPN environment:
  1. Upgrade a secondary KS first and wait until COOP KS election is completed.
  2. Repeat Step1 for all secondary KSs.
  3. Upgrade the primary KS.
  4. Upgrade GMs.
From <http://www.cisco.com/c/en/us/support/docs/security/group-encrypted-transport-vpn/118125-technote-getvpn-00.html
