GRT AND VRF Routing Leaking using OSPF
uni1389
Hello All ;
I am trying to do Route leaking of Default route from GRT to MP BGP VPN4 and CPE having VRF OSPF instance as mentioned below but still am not able to do. I want to access internet from CPE35 . Below are some show output for your feedback and support.
Site01Edge101# show run | sec router ospf
router ospf 1
router-id 10.10.100.101
network 0.0.0.0 255.255.255.255 area 0
Site01Edge101#show ip route Gateway of last resort is 10.10.10.66 to network 0.0.0.0
O*E2 0.0.0.0/0 [110/1] via 10.10.10.66, 06:24:12, GigabitEthernet0/1
10.0.0.0/8 is variably subnetted, 7 subnets, 3 masks
C 10.10.10.64/30 is directly connected, GigabitEthernet0/1
L 10.10.10.65/32 is directly connected, GigabitEthernet0/1
O 10.10.10.68/30 [110/2] via 10.10.10.66, 06:30:03, GigabitEthernet0/1
O 10.10.100.100/32
C 10.10.100.101/32 is directly connected, Loopback0
C 10.10.152.0/24 is directly connected, GigabitEthernet0/0
L 10.10.152.101/32 is directly connected, GigabitEthernet0/0
O 192.168.0.0/24 [110/2] via 10.10.10.66, 06:30:03, GigabitEthernet0/1
RTR-CPE35#show running-config | sec router ospf
router ospf 33 vrf CUST-A
redistribute bgp 65000 subnets
network 10.10.150.0 0.0.0.255 area 0
router ospf 1
network 10.10.152.0 0.0.0.255 area 0
RTR-CPE35#show running-config | sec router bgp
router bgp 65000
bgp log-neighbor-changes
redistribute connected
redistribute static
neighbor 192.168.100.36 remote-as 65000
neighbor 192.168.100.36 update-source Loopback0
neighbor 192.168.100.36 default-originate
neighbor 192.168.100.39 remote-as 65000
neighbor 192.168.100.39 update-source Loopback0
neighbor 192.168.100.39 default-originate
neighbor 192.168.100.40 remote-as 65000
neighbor 192.168.100.40 update-source Loopback0
neighbor 192.168.100.40 default-originate
address-family vpnv4
neighbor 192.168.100.36 activate
neighbor 192.168.100.36 send-community extended
neighbor 192.168.100.39 activate
neighbor 192.168.100.39 send-community extended
neighbor 192.168.100.40 activate
neighbor 192.168.100.40 send-community extended
exit-address-family
address-family ipv4 vrf CUST-A
redistribute ospf 33
default-information originate
exit-address-family
interface GigabitEthernet0/1
vrf forwarding CUST-A
ip address 10.10.150.35 255.255.255.0
duplex auto
speed auto
media-type rj45
RTR-CPE35#show ip route vrf CUST-A
Routing Table: CUST-A
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.150.0/24 is directly connected, GigabitEthernet0/1
L 10.10.150.35/32 is directly connected, GigabitEthernet0/1
192.168.33.0/32 is subnetted, 1 subnets
O 192.168.33.33 [110/2] via 10.10.150.33, 05:16:07, GigabitEthernet0/1
RTR-CPE35# SHOW RUN INT G0/1
Building configuration...
Current configuration : 140 bytes
duplex auto
speed auto
media-type rj45
end
RTR-CPE35#
Gateway of last resort is 10.10.152.101 to network 0.0.0.0
O*E2 0.0.0.0/0 [110/1] via 10.10.152.101, 05:03:09, GigabitEthernet0/0
10.0.0.0/8 is variably subnetted, 12 subnets, 3 masks
O 10.10.10.64/30
[110/2] via 10.10.152.101, 05:03:09, GigabitEthernet0/0
O 10.10.10.68/30
[110/3] via 10.10.152.101, 05:03:09, GigabitEthernet0/0
O 10.10.100.100/32
O 10.10.100.101/32
L 10.10.152.35/32 is directly connected, GigabitEthernet0/0
C 10.10.154.0/24 is directly connected, GigabitEthernet0/3
L 10.10.154.35/32 is directly connected, GigabitEthernet0/3
C 10.10.155.0/24 is directly connected, GigabitEthernet0/4
L 10.10.155.35/32 is directly connected, GigabitEthernet0/4
C 10.10.157.0/24 is directly connected, GigabitEthernet0/2
L 10.10.157.35/32 is directly connected, GigabitEthernet0/2
O 192.168.0.0/24 [110/3] via 10.10.152.101, 05:03:09, GigabitEthernet0/0
192.168.100.0/32 is subnetted, 1 subnets
C 192.168.100.35 is directly connected, Loopback0
RTR-CPE35#
RTR-CPE35#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/12/16 ms
RTR-CPE35#
RTR-CPE-33#show ip route
C 10.10.150.0/24 is directly connected, GigabitEthernet0/0
L 10.10.150.33/32 is directly connected, GigabitEthernet0/0
C 192.168.33.33 is directly connected, Loopback100
C 192.168.100.33 is directly connected, Loopback0
RTR-CPE-33#show run | sec
% Incomplete command.
RTR-CPE-33#
RTR-CPE-33# show run | sec router ospf
router ospf 33
router-id 192.168.33.33
network 192.168.33.33 0.0.0.0 area 0
RTR-CPE-33#
RTR-CPE-33#
RTR-CPE-33#show ip ospf ne
RTR-CPE-33#show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
10.10.150.35 1 FULL/DR 00:00:32 10.10.150.35 GigabitEthernet0/0
RTR-CPE-33#show ip int br
GigabitEthernet0/0 10.10.150.33 YES NVRAM up up
GigabitEthernet0/1 unassigned YES NVRAM up up
GigabitEthernet0/2 unassigned YES NVRAM down down
GigabitEthernet0/3 unassigned YES NVRAM down down
GigabitEthernet0/4 unassigned YES NVRAM down down
GigabitEthernet0/5 unassigned YES NVRAM down down
GigabitEthernet0/6 unassigned YES NVRAM down down
GigabitEthernet0/7 unassigned YES NVRAM down down
Loopback0 192.168.100.33 YES NVRAM up up
Loopback100 192.168.33.33 YES NVRAM up up
RTR-CPE-33#ping 10.10.150.35
Sending 5, 100-byte ICMP Echos to 10.10.150.35, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
RTR-CPE-33#
6 Replies 6
M02@rt37
Hello @uni1389
You could manually add a static default route into the VRF and redistribute it into MP-BGP ? The VRF defaut route will be announced to remote VRF sites via BGP VPNv4...
Best regards
filopeter
Hi, check the following features/documents
- BGP Support for IP Prefix Import from Global Table into a VRF Table
- BGP Support for IP Prefix Export from a VRF Table into the Global Table
https://www.cisco.com/c/en/us/td/docs/ios/12_2s/feature/guide/fs_bgivt.html
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-16-10/irg-xe-16-10-book/irg-prefix-export.html
uni1389
I have tried but still not getting to fix this issue.
router bgp 65000
redistribute ospf 1
exit-address-family
exit-address-family
router ospf 1
mpls ldp autoconfig
router-id 192.168.100.35
network 10.10.154.0 0.0.0.255 area 0
network 10.10.155.0 0.0.0.255 area 0
network 10.10.157.0 0.0.0.255 area 0
network 192.168.100.35 0.0.0.0 area 0
RTR-CPE35#show running-config | sec ip prefix
ip prefix-list CUST-A_TO_GRT seq 5 permit 192.168.33.33/32
ip prefix-list GLOBAL_TO_VRF seq 5 permit 0.0.0.0/0
ip prefix-list GLOBAL_TO_VRF seq 15 permit 10.10.152.0/24
ip prefix-list GLOBAL_TO_VRF seq 25 permit 10.10.100.101/32
RTR-CPE35#show running-config | sec route-map
route-map GLOBAL_TO_VRF_CUST-A permit 10
match ip address prefix-list GLOBAL_TO_VRF
route-map VRF-CUST-A-GRT permit 10
match ip address prefix-list CUST-A_TO_GRT
Please provide following outputs for troubleshooting purposes:
show ip vrf detail
show ip bgp vpnv4 all
My config is mentioned below
router bgp 65000
neighbor 192.168.100.37 remote-as 65000
neighbor 192.168.100.37 update-source Loopback0
neighbor 192.168.100.38 remote-as 65000
neighbor 192.168.100.38 update-source Loopback0
address-family ipv4
redistribute ospf 1 match internal external 1 external 2
neighbor 192.168.100.37 activate
neighbor 192.168.100.37 send-community extended
neighbor 192.168.100.38 activate
neighbor 192.168.100.38 send-community extended
neighbor 192.168.100.38 default-originate
exit-address-family
exit-address-family
network 10.10.150.0
redistribute static
redistribute ospf 33 match internal external 1 external 2
exit-address-family
router-id 192.168.200.35
network 192.168.200.35 0.0.0.0 area 0
router ospf 1
mpls ldp autoconfig
Current configuration : 9261 bytes
! Last configuration change at 13:57:21 UTC Mon Oct 27 2025
version 15.9
hostname RTR-CPE35
boot-start-marker
boot-end-marker
vrf definition CUST-A
rd 100:100
address-family ipv4
import ipv4 unicast map GLOBAL_TO_VRF_CUST-A
export ipv4 unicast map VRF-CUST-A-GRT
route-target export 100:100
route-target import 100:100
exit-address-family
ip prefix-list CUST-A_TO_GRT seq 15 permit 10.10.150.0/24
ip prefix-list CUST-A_TO_GRT seq 25 permit 172.16.33.0/24
  RTR-CPE35#show ip vrf detail
VRF CUST-A (VRF Id = 1); default RD 100:100; default VPNID <not set>
New CLI format, supports multiple address-families
Flags: 0x180C
Interfaces:
Lo100 Gi0/1
Address family ipv4 unicast (Table ID = 0x1):
Flags: 0x2100
Export VPN route-target communities
RT:100:100
Import VPN route-target communities
RT:100:100
Import route-map for ipv4 unicast: GLOBAL_TO_VRF_CUST-A (prefix limit: 1000)
Global export route-map for ipv4 unicast: VRF-CUST-A-GRT (prefix limit: 1000)
No export route-map
VRF label distribution protocol: not configured
VRF label allocation mode: per-prefix
RTR-CPE35#show ip bgp vpnv4 all
BGP table version is 6, local router ID is 192.168.100.35
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 100:100 (default for vrf CUST-A)
Import Map: GLOBAL_TO_VRF_CUST-A, Address-Family: IPv4 Unicast, Pfx Count/Limit: 2/1000
Export Map: VRF-CUST-A-GRT, Address-Family: IPv4 Unicast, Pfx Count/Limit: 2/1000
*> 10.10.100.101/32 10.10.152.101 2 32768 ?
*> 10.10.150.0/24 0.0.0.0 0 32768 ?
*> 10.10.152.0/24 0.0.0.0 0 32768 ?
*> 192.168.33.33/32 10.10.150.33 2 32768 ?
*> 192.168.200.35/32
0.0.0.0 0 32768 ?
RTR-CPE35#show ip int br
GigabitEthernet0/0 10.10.152.35 YES NVRAM up up
GigabitEthernet0/1 10.10.150.35 YES NVRAM up up
GigabitEthernet0/2 10.10.157.35 YES NVRAM administratively down down
GigabitEthernet0/3 10.10.154.35 YES NVRAM administratively down down
GigabitEthernet0/4 10.10.155.35 YES NVRAM administratively down down
GigabitEthernet0/6 192.168.0.28 YES NVRAM administratively down down
GigabitEthernet0/8 unassigned YES NVRAM down down
GigabitEthernet0/9 unassigned YES NVRAM down down
GigabitEthernet0/10 unassigned YES NVRAM down down
GigabitEthernet0/11 unassigned YES NVRAM down down
Loopback0 192.168.100.35 YES NVRAM up up
Loopback100 192.168.200.35 YES NVRAM up up
NVI0 10.10.150.35 YES unset up up
RTR-CPE35# show ip route
O*E2 0.0.0.0/0 [110/1] via 10.10.152.101, 00:01:58, GigabitEthernet0/0
10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
O 10.10.10.64/30
[110/2] via 10.10.152.101, 05:21:33, GigabitEthernet0/0
O 10.10.10.68/30
[110/3] via 10.10.152.101, 05:21:33, GigabitEthernet0/0
O 10.10.100.100/32
O 10.10.100.101/32
B 10.10.150.0/24 is directly connected, 05:21:33, GigabitEthernet0/1
O 192.168.0.0/24 [110/3] via 10.10.152.101, 00:02:05, GigabitEthernet0/0
B 192.168.33.33 [20/2] via 10.10.150.33, 05:21:33, GigabitEthernet0/1
RTR-CPE35# ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/13/15 ms
RTR-CPE35#
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
O E2 10.10.100.101/32
[110/1] via 10.10.150.35, 05:20:19, GigabitEthernet0/0
O E2 10.10.152.0/24 [110/1] via 10.10.150.35, 05:20:19, GigabitEthernet0/0
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.33.0/24 is directly connected, GigabitEthernet0/1
L 172.16.33.1/32 is directly connected, GigabitEthernet0/1
192.168.200.0/32 is subnetted, 1 subnets
O 192.168.200.35 [110/2] via 10.10.150.35, 06:00:55, GigabitEthernet0/0
GigabitEthernet0/1 172.16.33.1 YES NVRAM up up
RTR-CPE-33#ping 192.168.0.1
Success rate is 0 percent (0/5)
RTR-CPE-33#
IP Prefix import and export works only with prefixes learned by BGP. You must have them in BGP table for import/export purposes.
In your case the default route in the global routing table is learned by ospf, not by bgp.
To make your configuration working, try to configure
router bgp 65000
network 0.0.0.0
this command will insert 0.0.0.0/0 into BGP if there is 0.0.0.0/0 in the routing table.
Then please check if the routing table on RTR-CPE35 vrf CUST-A contains the default route
If you will see a default route in the vrf routing table, this will be a good point. The default route should then be advertised using ospf 33 to RTR-CPE-33. Then try once again ping 192.168.0.1 from RR-CPE-33
