07-18-2005 03:41 PM
Here are are following configuration.
PE1 :(cisco 5509 series switch)
ip vrf wholesaler1
rd 10:10
route-target export 10:10
route-target import 10:10
ip vrf wholesaler2
rd 10:11
route-target export 10:11
route-target import 10:11
ip cef
interface Loopback0
ip address 137.172.0.2 255.255.255.255
no ip route-cache
no ip mroute-cache
interface Vlan100 (created between two PE)
ip address 202.61.12.1 255.255.255.240
ip directed-broadcast
tag-switching ip
interface Vlan200 (created betwwen PE1 to alteon switch)
ip vrf forwarding wholesaler1
ip address 202.61.12.241 255.255.255.252
interface Vlan201 (created betwwen PE1 to alteon switch)
ip vrf forwarding wholesaler2
ip address 202.61.12.245 255.255.255.252
router ospf 1
network 137.172.0.2 0.0.0.0 area 0
network 202.61.12.1 0.0.0.0 area 0
passive-interface lo0
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 137.172.0.3 remote-as 18192
neighbor 137.172.0.3 update-source lo0
no auto-summary
address-family ipv4 vrf wholesaler1
neighbor 202.61.12.241 remote-as 18192
no auto-summary
no synchronization
exit-address-family
neighbor 202.61.12.245 remote-as <as other than 18192>
no auto-summary
no synchronization
address-family vpnv4
neighbor 137.172.0.3 activate
neighbor 137.172.0.3 send-community extended
no auto-summary
exit-address-family
PE2 (cisco 5505 switch) :
ip vrf wholesaler1
rd 10:10
ip vrf wholesaler2
rd 10:11
ip cef
interface Loopback0
ip address 137.172.0.3 255.255.255.255
interface Vlan100 (PE-to-PE)
ip address 202.61.12.3 255.255.255.240
ip pim sparse-dense-mode
tag-switching ip
interface Vlan200 (PE-to-CE)
ip address 202.61.15.65 255.255.255.252
interface Vlan201 (PE-to-CE)
ip address 202.61.15.69 255.255.255.252
router ospf 1
network 137.172.0.3 0.0.0.0 area 0
network 202.61.12.3 0.0.0.0 area 0
router bgp 1
neighbor 137.172.0.2 remote-as 1
neighbor 137.172.0.2 update-source lo0
neighbor 202.61.15.66 remote-as 1414
no auto-summary
no synchronization
exit-address-family
neighbor 202.61.15.70 remote-as 1415
no auto-summary
no synchronization
exit-address-family
neighbor 137.172.0.2 act
neighbor 137.172.0.2 send-community extended
no auto-summary
exit-address-family
_____________________________________
Firewall is connected with nortel alteon switch???my question are below:-
Is it necessary to put ip vrf forwarding command towards nortel alteon switch??can i connect alteon switch to over one vlan interface with 5509 switch???
07-19-2005 06:20 AM
You are using the Alteon switch to loadbalance to several firewalls? And you want to have only one inside interface?
If so, and you can guarantee the Alteon switch doesn't allow packets to return to the MPLS-cloud without first getting checked by the firewalls, then you could setup a central VRF to deliver this functionality.
If you want to have separate inside firewall interfaces, then you could configure as you specified with the each vrf also located on the central side with each one having a VLAN-if into the central firewall..
I have put together a sample config for a central service:
On PE1:
! You dont need the wholesaler1/2 here unless you have something directly connected in these VRFs
no ip vrf wholesaler1
no ip vrf wholesaler2
ip vrf fw
rd 10:1
route-target import 10:99
interface Vlan200
description To Central Firewall Service
ip vrf forwarding fw
! Use the same BGP AS on your routers.. use RR if needed
router bgp 18192
! and the rest of your bgp-config
address-family ipv4 vrf fw
redistribute static
default-information originate
exit-address-family
no auto-summary
exit-address-family
ip route vrf fw 0.0.0.0 0.0.0.0 202.61.12.242
On PE2:
ip vrf wholesaler1
rd 10:10
route-target export 10:99
ip vrf wholesaler2
rd 10:11
router bgp 18192
neighbor 137.172.0.2 remote-as 18192
neighbor 137.172.0.2 activate
no auto-summary
exit-address-family
Did it help?
07-19-2005 03:41 PM
Hi Johansens,
Thanks for your reply.I am going to configure according to your suggestion,but did you want to say by doing above config am i able to ping all customers CEs from Alteon switch or from firewall?
So on PE1 I only configured FW vrf & forward it through VLAN200 & on PE2 configured diffrent vrf ...one for each customer & forward it to respective VLAN.Am I right?
07-20-2005 01:15 AM
I referred to the Alteon switch as if it has a Layer3 routing-function. It's the Layer3 next-hop and it's associated upstream next-hops which will be able to ping all the customers CEs and networks..
Yes, on PE1 it's the central VRF (fw) and on PE2 the different customer VRFs into their respective VLANs.
Did it help?
07-21-2005 03:53 PM
Hi Johansens,
Once again thanks for your reply...yes you are right.Alteon switch has layer-3 routing function.After applying above configuration I am able to ping all customers from alteon switch but not able to ping alteon switch or upstream devices from customer's device.From customer point of view when i put SH IP ROUTE command i get only default BGP route.
B* 0.0.0.0 20\0
I think this is alright,but I am not able to ping Alteaon switch???
Can you explain why it happens??
07-22-2005 04:09 AM
Hi again,
First of all, do this:
On PE1:
router bgp 18192
neighbor 137.172.0.3 next-hop-self
exit-address-family
On PE2:
router bgp 18192
neighbor 137.172.0.2 next-hop-self
exit-address-family
And try again.
If you can't ping the 202.61.12.242 address from the CE's, but you can ping the CE's from the 202.61.12.242 address, then there is something strange going on.
MPLS VPN ForwardingBasic troubleshooting steps
So, you have received report of a VPN traffic outage:
1. First, verify "VRF ping" from PE1 to PE2.
2. If passed, then either CE->PE or PE->CE might be the problem=>not a MPLS core problem. Stop and check whether the packets are getting dropped by ingress LC on PE.
3. If failed, then MPLS core might be the problem. Proceed.
4. "Ping" ingress PE to egress PE to verify the IP reachability.
5. If failed, STOP and verify egress PE's route hop by hop.
6. If passed, traceroute PE1->PE2 and PE2->PE1 to ensure the PE-to-PE LSP setup.
7. Check for the labels in each line of the traceroute output (watch out for the PHP).
8. If traceroute fails for some reason, stop and verify the label on every hop.
9. If good, the problem might be very specific to the HW on either PE or P routers. Find out if HW is dropping the packets.
Did it help?
