I need a help
papediop2585
Please i need the ROUTERWATCHER software of cisco on windows for my research! Thank for your help.
5 Replies 5
Peter Paluch
Hello Pape,
I am not aware of any such software made by Cisco and frankly, even after trying to find this software name on Google, I did not arrive at any conclusive results. In general, these forums are not intended for software exchange. If the software is not freely available, I do not believe anyone will be able to help.
Best regards,
Peter
Thank's for your Peter!
fsebera
Level 4
Level 4
Hey Pape,
Sounds like you are referring thy SolarWinds free tool, RouterWatcher.
Check the SolarWinds web site and report back what you find so others can benefit form as well!!!!!!
Frank
Ok fsebera no problem for your request
Hello Pape,
I think you can also go for GNS3 which is a simluation for Cisco IOS software for various ISR paltforms along with 7200's. You will also be able to use firewalls in the same for your testing.
http://www.gns3.net
Vinit
--Vinit
