interface vlan does not up!
huydien3384
Level 3
Level 3
Hi all,
I create a vlan follows an interface vlan, but the interface vlan does not up.
I'm using RSP7600 Adv IP Service with ES20 line card. Please help.
Thanks million!
shivlu jain
Level 9
Level 9
Create vlan on router also.
regards
shivlu jain
Certainly I've created vlan on router and shutdown, no shutdown interface vlan, but it still down 😞 Any suggestion?
A SVI interface for a VLAN X will be up/up if there is an access port alive in the VLAN X on the switch, or if there is a trunk port alive on the switch on which the VLAN X is allowed. Are these requirements met in your particular case?
Best regards,
Peter
