IOS need for MPLS for 3600 ruter
kamal-hossain
Hi all
I want to build a mpls lab using 3640 router can any one tell me which ios support mpls
mheusinger
Level 10
Level 10
use the latest Telco or Advanced Enterprise feature set. MPLS L3VPN (P and PE) and MPLS TE is supported. Some features might be missing compared to high end routers but the 3640 will still allow you to investigate MPLS in great detail.
If you are interested in configuration of f.e. VLANoMPLS I would also recommend to have a look at the c7200 router simulator allowing you to boot a REAL IOS with all the features of a 7200.
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Hope this helps! Please use the rating system.
Regards, Martin
Thanks Martin
If i use 7200 series router then will i get all feature of mpls like VLANoMPLS,FRR,traffice engineering based on QOS and psudowire mpls
Best regards
kamal
