IS-IS not available for redistribuition under AF in MP-BGP
Hi all,
I am labing MPLS L3 VPNs, and as I am trying different PE-CE routing protocols, I stumbled on a point where IS-IS is not being shown as an option to be redistributed into BGP as you can see below:
RP/0/0/CPU0:PE12#
RP/0/0/CPU0:PE12#sh run router bgp
Sun Mar 16 15:29:25.860 UTC
router bgp 240
address-family ipv4 unicast
address-family vpnv4 unicast
neighbor 14.1.1.1
remote-as 240
update-source Loopback10
vrf ccc
rd 240:300
redistribute connected
redistribute static
RP/0/0/CPU0:PE12#conf t
Sun Mar 16 15:30:00.347 UTC
RP/0/0/CPU0:Mar 16 15:30:00.887 UTC: config[65742]: %HA-HA_WD_LIB-6-REG_PROC_SUCCESS : Memory state registration is success
RP/0/0/CPU0:PE12(config)#
RP/0/0/CPU0:PE12(config)#router bgp 240
RP/0/0/CPU0:PE12(config-bgp)#vrf ccc
RP/0/0/CPU0:PE12(config-bgp-vrf)#address-family ipv4
% Incomplete command.
RP/0/0/CPU0:PE12(config-bgp-vrf)#address-family ipv4 uni
RP/0/0/CPU0:PE12(config-bgp-vrf-af)#
RP/0/0/CPU0:PE12(config-bgp-vrf-af)#redistribute ?
application OnePK application routes
connected Connected routes
eigrp Enhanced Interior Gateway Routing Protocol (EIGRP)
lisp Locator/ID Separation Protocol (LISP)
mobile Mobile routes
ospf Open Shortest Path First (OSPF)
rip Routing Information Protocol (RIP)
static Static routes
subscriber subscriber routes
As you can see, there is no IS-IS in the options above. What  am I doing wrong?
This is the version of IOS XR I am using on EVE-NG:
RP/0/0/CPU0:PE12#
RP/0/0/CPU0:PE12#sh ver | i image
Sun Mar 16 15:33:27.843 UTC
System image file is "bootflash:disk0/xrvr-os-mbi-6.6.2.10I/mbixrvr-rp.vm"
RP/0/0/CPU0:PE12#
RP/0/0/CPU0:PE12#
TIA.
Harold Ritter
Hi @Wassamba Muyengu ,
It is supported in more recent IOS-XR versions.
By the way, the utilization of isis as a PE-CE routing protocol is very marginal in the production networks worldwide.
Harold Ritter
Thanks Harold.
You are very welcome @Wassamba Muyengu and thanks for the feedback
