MAX numbers for BGP prefixes on ASR9001 (scalability)
Mario Rosi
Someone has the official numbers for IPv4 BGP prefixes, IPv6 BGP prefixes of ASR9001?
I would use 4x ASR9001 as ASBR in full mesh iBGP peering among themselves and for a double eBGP peering with two upstream ISPs; they than would generate a 0/0 towards the internal iBGP peers.
So, they would receive the FRT from the eBGP peer and 3 other copies from the iBGP peers.
This is the HW:
RP/0/RSP0/CPU0:MIX-ASR9K1-EDGE1#sh platform
Wed Aug 16 16:00:12.006 summertime
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-2X10GE OK PWR,NSHUT,MON
0/0/1 A9K-MPA-2X10GE OK PWR,NSHUT,MON
RP/0/RSP0/CPU0:MIX-ASR9K1-EDGE1#sh diag summary
Wed Aug 16 16:00:44.162 summertime
NODE module 0/RSP0/CPU0 ASR 9001, Route Switch Processor with 8GB memory
NODE module 0/0/CPU0 ASR 9001, Modular Line Card
SPA 0/0/0 : ASR 9000 2-port 10GE Modular Port Adapter
RP/0/RSP0/CPU0:MIX-ASR9K1-EDGE1#sh ver
Wed Aug 16 16:00:59.245 summertime
Cisco IOS XR Software, Version 4.2.3[Default]
Copyright (c) 2013 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 1.29(20120327:203546) [ASR9K ROMMON],
MIX-ASR9K1-EDGE1 uptime is 3 years, 14 weeks, 3 days, 16 hours, 46 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-4.2.3.CSCuf38249-1.0.0/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
2 Management Ethernet
8 TenGigE
8 DWDM controller(s)
8 WANPHY controller(s)
219k bytes of non-volatile configuration memory.
2940M bytes of hard disk.
4014064k bytes of disk0: (Sector size 512 bytes).
Mario
9 Replies 9
balaji.bandi
check below thread may help you :
https://community.cisco.com/t5/xr-os-and-platforms/asr-bgp-routing-max-prefix/td-p/3916660
BB
M02@rt37
Hello @Mario Rosi,
On your router bgp instance, choose a neighbor and under 'address-familly ipv4 unicast' enter the command maximum-prefix ?
Is that give you a range ?
Max default value should be 1048576.
Best regards
Hi M02@rt37
PREVIEW
i get this number:
RP/0/RSP0/CPU0:MIX-ASR9K1-EDGE1(config-bgp-nbr)#address-family ipv4 unicast
RP/0/RSP0/CPU0:MIX-ASR9K1-EDGE1(config-bgp-nbr-af)#maximum-prefix ?
<1-4.294.967.295> maximum no. of prefix limit
so it means 4Bilion? mmmhhh.. it looks too much!
However, i was more interested on the limit per platform, totally...
OK @Mario Rosi.
For an idea, in terms of routes (asr 9000 series, 5.3.x release):
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/routing/configuration/guide/b_routing_cg53xasr9k/b_routing_cg53xasr9k_chapter_010.html
Best regards
M02@rt37 just to be sure,
when it says 1.3 million of IPv4 routes, doesn't mean BGP prefixes in BGP table right? It means properly prefixes present in RIB, routing table, i mean, best path of BGP imported in routing table.
Because otherwise with almost 1M of BGP prefixes present in FRT, already two external peers towards two different IPSs, leaving from the same ASR9001, would cause the crash of it.
Mario
Yes you're right @Mario Rosi, RIB view, not only BGP prefixes learned.
Best regards
M02@rt37  good,
so it means much more BGP prefixes than 1.3M... so now the question is, how many BGP prefixes in global routing table the ASR9001 can keep?
I'd have the necessity to understand if 4M of BGP prefixes (among which BGP best path algorithm would choose less than 1M entries to inject in RIB) can be managed by this guy...
@Mario Rosi,
Please provide #show cef platform resource location output please.
Best regards
#show cef platform resource location 0/0/CPU0
Wed Aug 16 18:16:27.171 Italy
Node: 0/0/CPU0
RPF_STRICT usage is same on all NPs
NP: 0 struct 9: RPF_STRICT (maps to ucode stru = 16)
Used Entries: 0 Max Entries: 262144
IP_LEAF_P usage is same on all NPs
NP: 0 struct 23: IP_LEAF_P (maps to ucode stru = 9)
Used Entries: 5465 Max Entries: 4194304
NP: 0 struct 24: IP_LEAF_P (maps to ucode stru = 42)
Used Entries: 47 Max Entries: 2097152
NP: 0 struct 4: IP_LEAF (maps to ucode stru = 11)
Used Entries: 966761 Max Entries: 4194304
NP: 1 struct 4: IP_LEAF (maps to ucode stru = 11)
Used Entries: 966760 Max Entries: 4194304
TX_ADJ usage is same on all NPs
NP: 0 struct 12: TX_ADJ (maps to ucode stru = 5)
Used Entries: 24 Max Entries: 524288
NR_LDI usage is same on all NPs
NP: 0 struct 7: NR_LDI (maps to ucode stru = 13)
Used Entries: 133176 Max Entries: 2097152
TE_NH_ADJ usage is same on all NPs
NP: 0 struct 14: TE_NH_ADJ (maps to ucode stru = 7)
Used Entries: 8 Max Entries: 65536
RX_ADJ usage is same on all NPs
NP: 0 struct 13: RX_ADJ (maps to ucode stru = 4)
Used Entries: 30 Max Entries: 131072
NP: 0 struct 6: R_LDI (maps to ucode stru = 12)
Used Entries: 148 Max Entries: 131072
L2VPN_LDI usage is same on all NPs
NP: 0 struct 16: L2VPN_LDI (maps to ucode stru = 27)
Used Entries: 24 Max Entries: 32768
