More than One PE interface in same VRF
I need you help , for a scenario of L3VPN (MPLS VPN) , for same customer in different sites connected to a single PE router then how can i configure to put different PE router interfaces in same VRF for a single customer (CUSTOMER-A) for example .
Here is my scenario - IP overlap warning/error shown by IOS .
Please suggest .
Harold Ritter
Hi Vikrant,
The issue is that you are trying to use the same subnet (192.168.1.0/24) on two different interfaces, which is causing the overlap error message. You could use 192.168.1.0/24 on the first interface and 192.168.2.0/24 on the other, for instance.
Thanks for writing , if i want a single large subnet not further subnetted then i think i have to go with l2vpn , rather than l3vpn as here for every rd there is one subnet and more than one interface not in same vrf .
Please suggest .
