MP BGP vpnv4 issue
alex.dersch
Level 4
Level 4
i have some problems with routing updates in my mpls could. i have three routers, one is configured as route reflector the other two are clients. I have three vrf's configured. The topology and config is attched.
on the router p1 i do net get any routing information from the other sites.
here the output from p2
show ip bgp vpnv4 rd 65000:100
BGP table version is 13, local router ID is 172.16.131.252
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65000:100 (default for vrf NCS)
*>  172.22.3.0/29    0.0.0.0                  0         32768 ?
*>  172.22.3.241/32  0.0.0.0                  0         32768 ?
here the output from p1
*>  0.0.0.0          172.22.25.6              1         32768 ?
*   10.0.9.0/24      172.22.25.238            1         32768 i
*>                   172.22.9.6               2         32768 ?
*>  91.198.79.0/25   172.22.25.6             20         32768 ?
*>  172.22.0.0/29    172.22.25.238            1         32768 i
* i                  172.16.128.252           0    100      0 ?
*>  172.22.0.241/32  172.22.25.238            1         32768 i
*>  172.22.0.242/32  172.22.25.238            1         32768 i
* i                  172.16.128.252          11    100      0 ?
*>i 172.22.3.0/29    172.16.131.252           0    100      0 ?
*>i 172.22.3.241/32  172.16.131.252           0    100      0 ?
and here from p3
BGP table version is 2367, local router ID is 172.16.128.252
*>i0.0.0.0          172.16.130.252           1    100      0 ?
*>i10.0.9.0/24      172.16.130.252           1    100      0 i
* i                 172.16.130.252           2    100      0 ?
* i                 172.16.138.252           3    100      0 ?
*>i91.198.79.0/25   172.16.130.252          20    100      0 ?
* i172.22.0.0/29    172.16.130.252           1    100      0 i
*>                  0.0.0.0                  0         32768 ?
* i172.22.0.241/32  172.16.130.252           1    100      0 i
* i172.22.0.242/32  172.16.130.252           1    100      0 i
*>                  172.22.0.6              11         32768 ?
*>i172.22.3.0/29    172.16.138.252           1    100      0 i
* i                 172.16.131.252           0    100      0 ?
*>i172.22.3.241/32  172.16.138.252           1    100      0 i
somehow the bgp session is established but vpnv4 doesn't get established.
P1
show ip proto | begin bgp
Routing Protocol is "bgp 65000"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Route Reflector for address family VPNv4 Unicast, 3 clients
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    172.16.131.252
    172.16.135.252
  Maximum path: 1
  Routing Information Sources:
    Gateway         Distance      Last Update
    172.16.131.252       200      00:01:00
  Distance: external 20 internal 200 local 200
P2 #show ip proto | begin bgp
*** IP Routing is NSF aware ***
  Neighbor(s):
    172.16.130.252
  Maximum path: 1
P3
  Neighbor(s):
    172.16.130.252
  Maximum path: 1
    172.16.130.252       200      00:01:44
on the p1 i get every couple minutes this
Aug 14 18:27:04.115: %BGP-5-NBR_RESET: Neighbor 172.16.131.252 reset (Peer closed the session)
Aug 14 18:27:04.115: %BGP-3-NOTIFICATION: received from neighbor 172.16.131.252 4/0 (hold time expired) 0 bytes
Aug 14 18:27:04.119: %BGP-5-ADJCHANGE: neighbor 172.16.131.252 Down Peer closed the session
Aug 14 18:27:04.119: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.131.252 VPNv4 Unicast topology base removed from session  Peer closed the session
Aug 14 18:27:04.119: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.131.252 IPv4 Unicast topology base removed from session  Peer closed the session
Aug 14 18:27:14.363: %BGP-5-ADJCHANGE: neighbor 172.16.131.252 Up
on p2 i get this
*Aug 14 18:26:52.935: %BGP-3-NOTIFICATION: sent to neighbor 172.16.130.252 4/0 (hold time expired) 0 bytes
*Aug 14 18:26:52.935: %BGP-5-NBR_RESET: Neighbor 172.16.130.252 reset (BGP Notification sent)
*Aug 14 18:26:52.935: %BGP-5-ADJCHANGE: neighbor 172.16.130.252 Down BGP Notification sent
*Aug 14 18:26:52.935: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.130.252 VPNv4 Unicast topology base removed from session  BGP                                  Notification sent
*Aug 14 18:26:52.935: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.130.252 IPv4 Unicast topology base removed from session  BGP N                                 otification sent
*Aug 14 18:27:03.179: %BGP-5-ADJCHANGE: neighbor 172.16.130.252 Up
any idea why this happens?
The p2 and p1 are 2900 running 153-3.M.
thanks in advanced
Alex
alex.dersch
Level 4
Level 4
I found the issue, it was a mtu mismatch,
