mpls ATM control-vc command
Walter1972_2
Hello
I am having difficulty understanding the following commands:
int ATM 3/0.2
mpls ip
mpls atm 2-3
mpls atm control-vc 5 31
Should I not have mpls atm control-vc X 31 where X either value 2 or 3?
I thought the 5 was the VPI which must fall within the range specified in the mpls atm 2-3?
In other words - how can the value 5 differ from 2-3?
Thank you for explaining
Walter
Giuseppe Larosa
Hello Walter,
this should be legitimate configuration
in ATM mode MPLS LSP are created on demand as SVCs so the control channel can use a different VPI value
the command
mpls atm 2-3
says that SVCs created on demand will have VPI 2 or 3 and this provides a moderate label space (not very big in comparison to packet based MPLS)
I would say this is even more clear and clean as a configuration
I may be wrong but reserved VCI values 0-31 exist when VPI = 0 not for non zero VPI values.
all the LDP messages will travel on 5/31 with no risk of interference with SVCs
Hope to help
Giuseppe
Thanks Giuseppe
This explains it well!
