MPLS Basics
georgecharlesk
Community Member
Could you please tell me whether MPLS VPN's are Layer 2 VPN or Layer 3?
jmia
Level 11
Level 11
You can have MPLS L2 & L3 VPNs. More info can be found here:
http://www.cisco.com/warp/public/732/Tech/mpls/
Hope this helps,
Jay
MPLS VPN refers to L3VPN. There is other Cisco terminology for L2VPN such as AToM or EoMPLS.
Hope this helps,
crahbari
Visitor
There are both layer 3 (MPLS over an IP network), and layer 2 MPLS ( MPLS over FR or ATM network). MPLS itself is considered to provide a layer 2 type of security whether it is carried over a layer 3 or a layer 2 network.
mithil_r
Level 2
Level 2
Hi George,
The most significant difference is in how PE-CE router relations are handled. In a Layer 2 MPLS VPN, the PE router is not a peer to the CE router and does not maintain separate routing tables. Rather, it simply maps incoming Layer 2 traffic onto the appropriate point-to-point tunnel. The result is best described as an "overlay" model as opposed to the Layer 3 "peer" model.
Check this link for more clarification:
http://www.foundrynet.com/solutions/appNotes/MPLS_L3vsL2.html#i
