MPLS CSC Sham-link Problem
lvpin Lv
Hello everyone I am a for students from China, here is my problem, my English is not good, this is done by google translate.
Lab Topology
Narrative
Blue link ,Is the backdoor link
R3-RR and R8-RR   backdoor link,Everything is normal
R1-CE and R10-CE  backdoor link ,Problem occurs
Among ,R2-PE of F0/0,R4-PE of F0/0,R6-PE of F0/1 ,R9-PE of F0/1,is VRF Interface,As shown。
Experimental phenomena
R1-CE 《——》 R10-CE     backdoor link
FULL  OR  DOWN
R2#
*Oct 14 17:34:49.675: %SYS-5-CONFIG_I: Configured from console by console
R2#
*Oct 14 17:34:52.063: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from LOADING to FULL, Loading Done
R2#
*Oct 14 17:34:56.147: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from FULL to DOWN, Neighbor Down: Interface down or detached
R2#
*Oct 14 17:35:02.063: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from LOADING to FULL, Loading Done
R2#
*Oct 14 17:35:06.183: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from FULL to DOWN, Neighbor Down: Interface down or detached
R2#
*Oct 14 17:35:12.219: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from LOADING to FULL, Loading Done
R2#
*Oct 14 17:35:16.203: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL3 from FULL to DOWN, Neighbor Down: Interface down or detached
R2#
*Oct 14 17:35:19.219: %OSPF-4-ERRRCV: Received invalid packet: Bad LLS Checksum from 12.1.1.1, FastEthernet0/0
_______________________________________________________________________
OR .......
Without any Experimental phenomena
Neighbors will not FULL,Will not DOWN
How to solve this situation?
However, I did not
R2(config)#route ospf 12 vrf a
network 【Loopback  VRF interface address】
Experimental configuration  summary
R1-CE
router ospf 12
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 1
router-id 10.1.1.1
network 10.1.1.1 0.0.0.0 area 0
network 12.1.1.0 0.0.0.255 area 0
network 110.1.1.0 0.0.0.255 area 0
R2-PE
R2#show run | s ospf
router ospf 12 vrf a
mpls traffic-eng area 0
router-id 22.22.22.22
area 0 sham-link 22.22.22.22 99.99.99.99 ttl-security hops 254
redistribute bgp 1 metric 10 subnets
R2#show run | b r b
router bgp 1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 30.1.1.1 remote-as 1
neighbor 30.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 30.1.1.1 activate
exit-address-family
address-family vpnv4
  neighbor 30.1.1.1 send-community extended
exit-address-family
address-family ipv4 vrf a
  network 22.22.22.22 mask 255.255.255.255
  redistribute ospf 12 metric 10
exit-address-family
interface Loopback10
ip vrf forwarding a
ip address 22.22.22.22 255.255.255.255
R3 -RR
R3#show run | b r b
router bgp 1
neighbor 20.1.1.1 remote-as 1
neighbor 20.1.1.1 update-source Loopback0
neighbor 80.1.1.1 remote-as 3
neighbor 80.1.1.1 ebgp-multihop 255
neighbor 80.1.1.1 update-source Loopback0
address-family ipv4
exit-address-family
  neighbor 20.1.1.1 activate
  neighbor 20.1.1.1 send-community extended
  neighbor 20.1.1.1 route-reflector-client
  neighbor 80.1.1.1 activate
  neighbor 80.1.1.1 send-community extended
exit-address-family
R3#show run | s ospf
router ospf 234
redistribute bgp 1
network 23.1.1.0 0.0.0.255 area 0
network 30.1.1.1 0.0.0.0 area 0
network 34.1.1.0 0.0.0.255 area 0
R4-PE
R4#show run | s ospf
router ospf 234 vrf a
mpls traffic-eng router-id FastEthernet0/0
area 0 sham-link 44.44.44.44 66.66.66.66 ttl-security hops 254
redistribute bgp 2 metric 10 subnets
router bgp 2
neighbor 60.1.1.1 remote-as 2
neighbor 60.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 60.1.1.1 activate
exit-address-family
  neighbor 60.1.1.1 send-community extended
exit-address-family
  network 22.22.22.22 mask 255.255.255.255     ——》【What is necessary?】
  network 44.44.44.44 mask 255.255.255.255
  redistribute ospf 234 metric 10
exit-address-family
R6-PE
router ospf 689 vrf a
area 0 sham-link 66.66.66.66 44.44.44.44 ttl-security hops 254
redistribute bgp 2 metric 5 subnets
network 68.1.1.0 0.0.0.255 area 0
R6#show run | b r b
router bgp 2
neighbor 40.1.1.1 remote-as 2
neighbor 40.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 40.1.1.1 activate
exit-address-family
  neighbor 40.1.1.1 send-community extended
exit-address-family
  network 66.66.66.66 mask 255.255.255.255
  network 99.99.99.99 mask 255.255.255.255
  redistribute ospf 689 metric 5
exit-address-family
R8-RR
router bgp 3
neighbor 30.1.1.1 ebgp-multihop 255
neighbor 90.1.1.1 remote-as 3
neighbor 90.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 90.1.1.1 activate
exit-address-family
  neighbor 90.1.1.1 send-community extended
  neighbor 90.1.1.1 route-reflector-client
exit-address-family
R9-PE
R9#show run | s ospf
router ospf 109 vrf a
router-id 99.99.99.99
area 0 sham-link 99.99.99.99 22.22.22.22 ttl-security hops 254
redistribute bgp 3 metric 5 subnets
network 109.1.1.0 0.0.0.255 area 0
router ospf 689
router-id 90.1.1.1
network 89.1.1.0 0.0.0.255 area 0
network 90.1.1.1 0.0.0.0 area 0
  redistribute ospf 109 metric 10
R9#SHOW RUN | b r b
router bgp 3
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
ip vrf forwarding a
ip address 99.99.99.99 255.255.255.255
R10-CE
router ospf 109
router-id 100.1.1.1
network 100.1.1.1 0.0.0.0 area 0
Configuration file download
Bye.
Thank Your.
Peter Paluch
You are redistributing BGP to OSPF. I believe that is a possible cause of your problem. The IP address of the loopback that is used as the endpoint of the sham link must be advertised only in BGP and not in OSPF. Otherwise, the OSPF will try to compute a route to the sham link endpoint and possibly create an unresolvable route.
Therefore, on all PE routers, remove the redistribute bgp command from the OSPF processes run in VRF a.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
You mean to prohibit
To the BGP routes redistribute OSPF to go?
I do the following operations
R9
  no redistribute ospf 109 metric 10
R2
no  redistribute ospf 12 metric 10
But still there are problems
1.
R2 vrf routing table to see the next hop 12.1.1.1 go 99.99.99.99
————》I modified the R1-R10 backdoor link cost,Neighbors are still unable to establish
*Oct 15 08:35:46.703: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL0 from INIT to DOWN, Neighbor Down: Interface down or detached
2.
I do not know  R2 Go 99.99.99.99 ,Establish a neighbor,Should be the path,backdoor link Or Backbone。
3.
I hope MPLS CSC and sham-link coexistence
So if no redistribute MPLS VPN will not be the normal possible
I did not find my configuration errors,
So I wish I could tell me how to configure to achieve the purpose of the experiment
Thank you very much!
Peter Paluc
bye
Problem has been solved
I found that, flip neighbor, Routing is also flip。
R2#show ip route vrf a
      99.0.0.0/32 is subnetted, 1 subnets
O E2     99.99.99.99 [110/5] via 80.1.1.1, 00:00:04
B        99.99.99.99 [200/0] via 80.1.1.1, 00:00:04
O E2   and  B  99.99.99.99  Constantly to switch
I performed the following operations
R2#
distance 201
R9
distance 201
Neighbors normal
*Oct 15 16:31:45.151: %OSPF-5-ADJCHG: Process 12, Nbr 99.99.99.99 on OSPF_SL0 from LOADING to FULL, Loading Done
R2#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
30.1.1.1          1   FULL/DR         00:00:38    23.1.1.3        FastEthernet0/1
10.1.1.1          1   FULL/BDR        00:00:39    12.1.1.1        FastEthernet0/0
99.99.99.99       0   FULL/  -        00:00:24    99.99.99.99     OSPF_SL0
R1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/32 is subnetted, 1 subnets
C        10.1.1.1 is directly connected, Loopback0
      12.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        12.1.1.0/24 is directly connected, FastEthernet0/0
L        12.1.1.1/32 is directly connected, FastEthernet0/0
      22.0.0.0/32 is subnetted, 1 subnets
O E2     22.22.22.22 [110/5] via 12.1.1.2, 00:00:48, FastEthernet0/0
O E2     99.99.99.99 [110/5] via 12.1.1.2, 00:00:48, FastEthernet0/0
      100.0.0.0/32 is subnetted, 1 subnets
O        100.1.1.1 [110/4] via 12.1.1.2, 00:00:48, FastEthernet0/0
      109.0.0.0/24 is subnetted, 1 subnets
O        109.1.1.0 [110/3] via 12.1.1.2, 00:00:48, FastEthernet0/0
      110.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        110.1.1.0/24 is directly connected, FastEthernet1/1
L        110.1.1.1/32 is directly connected, FastEthernet1/1
R1(config)#int f0/0
R1(config-if)#shu
R1(config-if)#shutdown
R1#show ip route
*Oct 15 16:33:15.627: %SYS-5-CONFIG_I: Configured from console by console
R1#show ip route
      12.0.0.0/24 is subnetted, 1 subnets
O        12.1.1.0 [110/10003] via 110.1.1.10, 00:00:09, FastEthernet1/1
O E2     22.22.22.22 [110/5] via 110.1.1.10, 00:00:09, FastEthernet1/1
O E2     99.99.99.99 [110/5] via 110.1.1.10, 00:00:09, FastEthernet1/1
O        100.1.1.1 [110/10001] via 110.1.1.10, 00:00:09, FastEthernet1/1
Thank you
Peter Paluch
Help
If you know the About  MPLS TE SRLG 。
I hope you can help me
https://supportforums.cisco.com/message/4025188#4025188
Thank you
bye
NEW  Configuration file download
