07-08-2025 07:47 PM
hi there !
Reading about MPLS TE Diffserv-Aware (DS-TE) IETF Mode, I have doubts about how the BC models direct traffic through a specific tunnel.Do I have to use MPLS TE Class-Based Tunnel Selection (CBTS) to steer traffic according exp field mapped to ct?
07-09-2025 12:22 AM
depends how the network and design looks :
check below post can give you some direction :
https://community.cisco.com/t5/mpls/mpls-ds-te-class-type/td-p/1479021
07-15-2025 01:51 AM
Rsvp use to draw path from one end to other' the class-type you config in one end is send with rsvp through path' inform the other routers how to select correct path according to affinity of link
MHM
07-19-2025 05:19 PM
So! for example if I configure a network to work with RDM or MAM model , Ill configure tunnel with a specific class(BCn) and to use a specific tunnel for a specific kind of traffic I can use CBTS?
