MPLS forwarding table outgoing interface drop?
Deniz AYDIN
Level 4
Level 4
what is mean outgoing interface drop in the output of
show mpls forwarding-table
command output
XXXX#show ip route vrf YYY 192.168.1.0
Routing entry for 192.168.1.0/24
Known via "bgp 6000", distance 200, metric 0, type internal
Last update from 192.168.128.77 00:06:59 ago
Routing Descriptor Blocks:
* 192.168.128.77 (Default-IP-Routing-Table), from 192.168.128.39, 00:06:59 ago
Route metric is 0, traffic share count is 1
AS Hops 0
MPLS Required
XXXX#
XXXX#
XXXX#
XXXX#show ip bgp vpnv4 vrf YYY 192.168.1.0
BGP routing table entry for 6000:5300:192.168.1.0/24, version 15713
Paths: (1 available, best #1, table YYY)
Not advertised to any peer
Local, imported path from 6000:4250:192.168.1.0/24
192.168.128.77 (metric 29) from 192.168.128.39 (192.168.128.39)
Origin IGP, localpref 100, weight 32768, valid, internal, best
Extended Community: RT:6000:4250 RT:6000:4800
Originator: 192.168.128.77, Cluster list: 0.0.0.10
mpls labels in/out nolabel/16
XXXX#
XXXX#
XXXX#
XXXX#show mpls forwarding-table vrf YYY 192.168.1.0 detail
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
None No Label 192.168.1.0/24[V] \
0 drop
MAC/Encaps=0/0, MRU=0, Label Stack{}
VPN route: YYY
No output feature configured
XXXX#
XXXX#
XXXX#
7 Replies 7
Giuseppe Larosa
Hello Deniz,
the vpnv4 route looks like imported in VRF YYY.
I would check
sh mpls forw 192.168.128.77 to see if LSP is correct to BGP next-hop.
>> MPLS required
This is the first step to do in my opinion.
Second note:
sh ip bgp vpnv4 vrf YYY 192.168.1.0 shows out label 16
but sh mpls forw vrf YYY 192.168.1.0 shows an empty label stack it should show the BGP label 16.
Hope to help
Giuseppe
Hi Giuseppe ,
It has correct next-hop record ,
XXXX#show mpls forwarding-table 192.168.128.77 detail
118 No Label 192.168.128.77/32 0 Gi0/3.201 192.168.122.2
MAC/Encaps=18/18, MRU=1504, Label Stack{}
0019E28498DB001380479319810000C90800
XXXX#
router gets the correct bgp label (i checked it from the other vpn nodes also) it seems it getting the correct tag from the downstream router. But its not installing it.
Hello Deniz,
I see
No Label as outgoing label for 192.168.128.177:
local label 118 but outgoing label no label
it should be a label value or pop tag.
check if you have a filter for label association and if LDP sessions are up with
sh mpls ldp discovery
Hope to help
Giuseppe
Hello Deniz
I also faced the same problem here
R1#sho ip route vrf ZZZ 10.5.82.242
Routing Table: ZZZ
Routing entry for 10.5.82.242/32
  Known via "static", distance 1, metric 0
  Redistributing via bgp 65000
  Advertised by bgp 65000
  * 10.5.82.97
R1#sho mpls forwarding-table vrf Gn_VRF 10.5.82.242
None   No Label      10.5.82.242/32[V]  0                   drop
I still trying to find the explanation about this on the internet, but I could solved this problem with action below
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#interface loopback 100
R1(config-if)#ip vrf forwarding ZZZ
R1(config-if)#ip address 10.5.82.242 255.255.255.255
R1(config-if)#no interface loopback 100
R1(config-if)#^Z
R1#sh mpls forwarding-table vrf Gn_VRF 10.5.82.242
250    No Label       10.5.82.242/32[V]  42318            Gi3/29      10.5.82.97
HI, I have the same problem now, but with several networks.
Do you found an explanetion for this behaviour ?
assuming you are using LDP to bind your prefixes you should try :
sh mpls ldp nei
#this is to check that your PE has an effective label distribution process
sh mpls for vrf YYY
#check what is happening inside your VRF in terms of mplsforwarding
sh ip cef vrf YYY A.B.C.D detail
#check the next hop in the CEF table.
Make sure the CEF table is on.
sh ip route vrf YYY
# check the routes inside your VRF
sh bgp vpnv4 uni all
# check the prefixes sourced by VPNv4
sh bgp vpnv4 uni all summ
#check the status of your BGP VPNv4 session
Alessio
Jan Linhart
Visitor
Is "ip cef" turned on? this is typical example how router behaves when cef is off.
