MPLS FRR compatibility issue C3745 IOS GNS3
ur7077
When I search for fast reroute on my mpls TE tunnel, I cannot find it. When I type in the command I see invalid input detected promt on the screen.  Please help me troubleshoot.
For you reference
R1(config-if)#tunnel mpls traffic-eng ?
  affinity        desired link attributes for links comprising tunnel
  auto-bw         Specify mpls tunnel should automatically change bw
  autoroute       parameters for IGP routing over tunnel
  bandwidth       tunnel bandwidth requirement
  load-share      Specify tunnel load-sharing metric
  path-option     a primary or fallback path setup option
  path-selection  Path Selection Configuration
  priority        tunnel priority
  record-route    record the route used by the tunnel
Thank you
Greetings thank you for the reply Giuseppe Larosa. That’s what I thought.
Giuseppe Larosa
Hello ur7077,
what IOS image is running on your emulated C3745 router ?
the MPLS FRR may be not supported on it.
Hope to help
Giuseppe
