mpls_ldp[1240]: %ROUTING-LDP-4-PEER_DUP_ADDRS : VRF 'default' (0x6000
psymonds7769
Getting this error message in the log:
mpls_ldp[1240]: %ROUTING-LDP-4-PEER_DUP_ADDRS : VRF 'default' (0x60000000), 1 Duplicate address(es) advertised by more than one peer
I'm not seeing more than 1 LDP peer advertising this IP however.
RP/0/RSP0/CPU0:BOITIDGDNN001#show mpls ldp structs dup-addr
Thu Aug 3 05:19:17.553 MDT
Duplicate Peer Addresses DB
Address: 10.16.135.94
peer 10.16.128.146:0 (pp 0x4a8ad034)
RP/0/RSP0/CPU0:BOITIDGDNN001#show mpls ldp neighbor | include 10.16.135.94
Thu Aug 3 05:22:39.063 MDT
10.16.134.234 10.16.135.70 10.16.135.81 10.16.135.94
Am I correct that only seeing 1 LDP peer means that there are not multiple peers that have this address bound to it, and that it's possibly a cosmetic bug?  I've configured a logging suppress rule in the meantime.
Harold Ritter
Hi @psymonds7769 ,
Can you run the following command:
show mpls ldp neighbor detail | include 10.16.135.94
10 Replies 10
M02@rt37
Hello @psymonds7769,
which platform and which IOS-Xr version?
Best regards
cisco ASR9K Series
asr9k-os-mbi-6.7.3/0x100000/mbiasr9k-rp
Harold Ritter
Hi @psymonds7769 ,
RP/0/RSP0/CPU0:BOITIDGDNN001#show mpls ldp neighbor detail | include 10.16.135.94
Thu Aug 3 08:51:18.578 MDT
10.16.135.94
Thanks for the information @psymonds7769 ,
You can clearly see in this output the this address is bound two different LDP neighbors.
Hi Harold
What is there to be done as soon as we discover the peers with the duplicate ip address ?  I am having the same issue presently
Thanks, regards
Paul
Hi @paul mebale ,
This is a misconfiguration. You need to make sure that the same IP address is not configured on two different neighbors.
allright.
Thank you @har
Best regards
AHHA!  I see it now!  Thanks!!
You are very welcome @psymonds7769 and thanks for the feedback
