mpls ldp password required vs fallback
sachin30720041
I am trying to understand the use of 'mpls ldp password required' command.  If I configure just the 'fallback' command but not the 'required' command ldp authentication still works. then what is the use of the 'required' command?
Sachin
That should not be the case. What router and OS are you using?
I just spun up a very basic network. R1 connects to R2 on G0/0. These are vIOS images running 15.8(3)M2
Here are the router configs with R1 setup to have fallback password only - R2 does not have any password config setup.
R1 config
R1#sh run int g0/0
interface GigabitEthernet0/0
 ip address 10.0.0.1 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 mpls ip
end
R1#sh run | i mpls ldp
mpls ldp password fallback cisco
R1#sh mpls ldp neigh det
    Peer LDP Ident: 10.0.0.2:0; Local LDP Ident 10.0.0.1:0
        TCP connection: 10.0.0.2.54779 - 10.0.0.1.646
        Password: not required, fallback, stale
        State: Oper; Msgs sent/rcvd: 14/14; Downstream; Last TIB rev sent 2
        Up time: 00:09:09; UID: 1; Peer Id 0;
        LDP discovery sources:
          GigabitEthernet0/0; Src IP addr: 10.0.0.2
            holdtime: 15000 ms, hello interval: 5000 ms
        Addresses bound to peer LDP Ident:
          10.0.0.2
        Peer holdtime: 180000 ms; KA interval: 60000 ms; Peer state: estab
        Capabilities Sent:
          [Dynamic Announcement (0x0506)]
          [Typed Wildcard (0x050B)]
        Capabilities Received:
R1#
R2 config
R2#sh run int g0/0
Building configuration...
Current configuration : 122 bytes
 ip address 10.0.0.2 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 mpls ip
end
R2#sh run | i mpls ldp
R2#sh mpls ldp neigh det
    Peer LDP Ident: 10.0.0.1:0; Local LDP Ident 10.0.0.2:0
        TCP connection: 10.0.0.1.646 - 10.0.0.2.54779
        Password: not required, none, in use
        State: Oper; Msgs sent/rcvd: 20/20; Downstream; Last TIB rev sent 2
        Up time: 00:14:42; UID: 1; Peer Id 0;
          GigabitEthernet0/0; Src IP addr: 10.0.0.1
          10.0.0.1
        Capabilities Sent:
R2#
As you can see in R1 config, I have configure the fallback command globally but the neighborship is up and the password is not required.
Here is the result of me adding the 'required' command globally on R1 (R2 still does not have any mpls ldp password config). As you can see, the neighborship instantly goes down.
R1 config (NOTE: the syslog message will continue to show up until I either configure the password on R2 or set R1 to not require password)
R1(config)#mpls ldp password required
R1(config)#
*Mar 31 23:58:01.712: %LDP-5-NBRCHG: LDP Neighbor 10.0.0.2:0 (1) is DOWN (Session's MD5 password changed)
*Mar 31 23:58:03.217: %TCP-6-BADAUTH: No MD5 digest from 10.0.0.2(30589) to 10.0.0.1(646) tableid - 0
*Mar 31 23:58:05.216: %TCP-6-BADAUTH: No MD5 digest from 10.0.0.2(30589) to 10.0.0.1(646) tableid - 0
*Mar 31 23:58:09.216: %TCP-6-BADAUTH: No MD5 digest from 10.0.0.2(30589) to 10.0.0.1(646) tableid - 0
R1#
R1#
R2 config
R2#
*Mar 31 23:58:02.117: %LDP-5-NBRCHG: LDP Neighbor 10.0.0.1:0 (1) is DOWN (Received error notification from peer: Holddown time expired)
R2#
** Please remember to mark this post if it was helpful. **
Anthony Sylvester
8 Replies 8
AnthonySylvester
Reference link: https://www.cisco.com/c/en/us/td/docs/ios/12_2sb/12_2sba/feature/guide/sba_md5.html#wp1046236
CommandDescription
mpls ldp password fallbackConfigures an MD5 password for LDP sessions with peers.
mpls ldp password optionConfigures an MD5 password for LDP sessions with neighbors whose LDP router IDs are permitted by a specified access list.
mpls ldp password requiredSpecifies that LDP must use a password when establishing a session between LDP peers.
Anthony Sylvester
Hi Anthony,
Thanks for responding.
If I configure 'mpls ldp password fallback <password>' command on a router then all its peers need 'mpls ldp password fallback <>' command configured. Then what is the use of the 'required' command? Do I need to configure 'required' command too?
Sachin
R1 config
R1#sh run int g0/0
 duplex auto
 speed auto
 media-type rj45
 mpls ip
end
          10.0.0.2
        Capabilities Sent:
R1#
R2 config
R2#sh run int g0/0
 duplex auto
 speed auto
 media-type rj45
 mpls ip
end
          10.0.0.1
        Capabilities Sent:
R2#
R1(config)#
R1#
R1#
R2 config
R2#
R2#
Anthony Sylvester
One question, you added the 'mpls ldp password fallback cisco' to the router after the ldp neighborship was established right? But if you add the command on R1 first then try to establish the neighborship then routers throw an authentication error right? But with the 'required' command we are forcing the routers to authenticate first and then establish the neighborship without clearing the LDP process. Right?
Hey Sachin,
Yes you are 100% correct.
Anthony Sylvester
The Password config
1- per-neighbor <- this is manual and must be match and manual enter in both Peer
2- global
in global you config many neighbor and forget one ??
here the fallback password use.
Can you please explain in other words? Thanks in advance.
make new post and I will build lab for this cases
MHM
