MPLS on Catalyst 3750ME
Antonio_1_2
does anyone have experience with MPLS on 3750ME working as PE router. Is it work fine, or it shouldn't be used for serious implementations?
I'm planning to use it for some minor locations in my network, but I've heard roumors that it has a lot of bugs.
thanks,
A.
ramprasadd
I worked on ME-6524 , It works fine as MPLS PE for aggregating L3-VPN's and L2-VPN's and no support for VPLS. It can be used as a spoke in H-VPLS Scenario. By looking at the product datasheet i had a feeling that they would have made ME 3750 in the similar lines.
thank you,
A.
