MPLS Over ATM
a-ragab
When we provision the frame relay access to MPLS we provision PVC from ATM BPX to MPLS Switch MAGX8850 so that the PVC assign from the Customer router port to ATM BPX Switch to PXM to RPM in the same time we create the MPLS VPN of a Customer then the Customer be connected to the new MPLS VPN with all members [Sites].
which all Packet traffic encapsolated to IP traffic which will lable at the header and forwad from origination to destination based on IP and routing protocol
between end-to-end.
this is for business IP [COS-Business].
From previously brief intruduction and because all MGX feeders and trunks via ATM BPX connectivity so can I say MPLS over ATM Network and because ATM BPX Network connectivity over Sonet OC-3 or higher so that can I say MPLS over ATM over Sonet with different levels and netwotk layers.
please feed back.
Ahmad
0 Replies 0
