MPLS over Layer 2
need some help from somebody that is experience at setting up MPLS Layer 2 point to multipoint
How to designing and implement
How MPLS Layer 2 is can be  used by service providers.
in which ways can be  configured is by l2 vpn over ip cloud with the help of l2tpv3
or to use over mpls backbone by using encapsulation mpls.
1- Can this be done on MPLS Layer 2, no physical   existence  only virtual
2- if yes how can I implement it point to multipoint senario
3- if no what is best solution  you recommend
help and pointers would be greatly appreciated.....
Kind Regards
Wael Abdelaliem
Have a look on the VPLS "Virtual Private LAN Services " guide:
http://www.cisco.com/en/US/docs/routers/7600/install_config/12.2SR_OSM_config/mpls.html#wp1423647
Wael
