MPLS ping not working between directly connected link
Karan ()
Hello Experts
I have a 7600 connected to ASR9k running OSPF and MPLS. I see the LDP neighborship is up and I can also see the labels allocated on both ASR9k and 7600 but when i do mpls ping to the neighbor loopback from 7600, i don't see a response.
Is it something that i need to configure on 7600 or ASR9k to get this working?
Vinit Jain
Do you know if mpls OAM is configured on ASR9k. By default, this feature is not enabled on XR devices. Based on the above description, you dont really need to configure anything on 7600.
Do you have the traffic flowing between these two devices?
Vinit
--Vinit
Vinit Jain
Vinit
--Vinit
Thanks for a quick response. I need to check ASR9k for MPLS OAM config.
As far as i know, there is no problem with the traffic.
Will get back to you.
It working now. mpls oam config was missing.
Thanks for your help.
