MPLS QOS
ajay chauhan
Level 7
Level 7
Here is the configuration attached.My question is this if i will c the report for class utilization ..its comes like 500 to 5000 % ..can you please explain what does it mean...class utilization can we more than 100%%.
class-map match-all cm_class4
match ip dscp default
class-map match-all cm_class3
match ip dscp af21
class-map match-all cm_class2
match ip dscp af31
class-map match-all cm_class1
match ip dscp ef
policy-map pm_inbound
class cm_class1
police cir 320000 bc 8192
priority
class cm_class2
bandwidth 900
queue-limit 128
class cm_class3
bandwidth 5900
queue-limit 407
class cm_class4
bandwidth 2300
queue-limit 407
class class-default
policy-map pm_from_ABC
class class-default
shape average 9500000
service-policy pm_inbound
5 Replies 5
network.king
Level 4
Level 4
Pls let me know how you are viewing the class utilisation in %.
I think you know that a class can utilise the bandwidth from other classes if they are free.
regards
vanesh k
actually i getting reports from lucent vital net ....there it shows ....utilizations for diffrent classs..so it comes like ....10-2000 % ..
You might be polling based on the bandwidth assigned to various classes and if the traffic in other classes is free , then one class can utilise the entire bandwidth .
eg . If a 10M link and one class is configured for 1 M , and other classes are free , then this class would use the entire 10M.
Pls check the utilisation by pummping traffic in all the classes.
regards
vanesh k
Hi Vanesh,
I got the answer...from your reply can you please clear my last doubt.
In configuration why we are using
# police cir 320000 bc 8192 for class1
for class 2 bandwidth is there .
class cm_class1
priority
class cm_class2
bandwidth 900
queue-limit 128
class cm_class3
bandwidth 5900
queue-limit 407
class cm_class4
bandwidth 2300
queue-limit 407
class class-default
but in this example
policy-map pm_outbound
class cm_class1
priority
class cm_class2
police cir 400000 bc 8192
bandwidth 400
queue-limit 128
both the classes are having cir values.
can u pls explain the same.
In your policy-map inbound , you have policing for one class , so that class would not be able to more bw than specified .But the other two classes , the bandwidth specified is the guaranteed amount of bandwidth when all the classes are utilising .But if other classes are not using then any class except the policed one would use the free bandwidth.
So in your case , inbound policy-map two classes would be able to have some exceeded utilisation . But your outbound cannot have exceeded values and they should display you the correct utilisation.
Hope this helps
regards
vanesh k
