05-22-2006 08:25 AM
Hello to All,
I have the following configuration;
CE1 ---->PE1
LAN: 172.21.0.0/16
CE2---->PE2
I have 2 CE (CE1 & CE2) which is connected on the same LAN (running HSRP). The CE's are connected to two different PE (PE1 & PE2). The routing protocol is RIPv2. My question is;
1. Do I need to enable SOO in the PE1 and PE2 router? (i.e. ip vrf sitemap)
2. When I redistribute BGP into RIP and vice versa, Do I need to filter the RIP in the PE routers (there might be some loop in the network)
3. Do you have sample configuration for this kind of setup?
Thanks.
05-22-2006 02:11 PM
with RIP there are some potential routing loop issues.
A route learned from a second site will be sent through f.e. PE1 to the CEs and learned again by PE2, which will consider this preferable over the iBGP route (RIP AD 120, iBGP AD 200). So you have to make sure that this does not happen.
Second, a route learned by one PE might be reinserted into RIP once the network is withdrawn by RIP (BGP table entry still in place).
So you should implement SOO and some filter for redistribution. One possible config - assuming IP addresses from 10.0.0.0/8 - would be:
CE1
router rip
version 2
network 10.0.0.0
no auto-summary
CE2
router rip
version 2
network 10.0.0.0
no auto-summary
PE1
interface Serial0/0
description to CE1
ip vrf forwarding Site1
ip vrf sitemap SOOSite1
ip address 10.1.0.1 255.255.255.252
router rip
address-family ipv4 vrf Stite1
version 2
redistribute bgp 65000 metric 14
!or whatever hopcount is needed in your topology, that the update does make it to CE2, but not to PE2
network 10.0.0.0
no auto-summary
router bgp 65000
redistribute rip
route-map SOOSite1 permit 10
set extcommunity soo 65000:1
PE2
interface Serial0/0
description to CE2
ip address 10.2.0.1 255.255.255.252
router rip
version 2
network 10.0.0.0
no auto-summary
router bgp 65000
redistribute rip
This should ensure to avoid possible routing loops.
Hope this helps! Please rate all posts.
Regards, Martin
05-22-2006 09:08 PM
Hello Martin,
You mentioned about implementing filter for redistribution. Does it mean that I have to do it on the rip routes (distribute-list) or in BGP or both?
If you dont mind, can you give a configuration example?
Thanks for the help.
05-22-2006 10:48 PM
you can filter the routes during redistribution like this:
router rip
redistribute bgp 65000 route-map RIP2BGP
route-map RIP2BGP permit 10
match ip address prefix-list 123
ip prefix-list 123 seq 5 permit 10.1.0.0/16 ge 16
The prefix-list defines the allowed (or disallowed using deny) networks.
Regards, Martin
05-23-2006 11:39 AM
Hello Martin,
Thanks for your help.
