07-08-2013 02:27 PM
I have the following network
CE1----OSPF------CE2
BGP(AS109) OSPF
PE1-------------------PE2
| ospf/ibgp |
| AS 9 |
P(RR)---------------------|
my goal from P is go to CE1-Lo0 via PE1
but it goes to PE1 - PE2 - CE2 - CE1
here the output of PE1
sho ip bgp vpnv4 all 172.9.0.11(CE1-LO)
BGP routing table entry for 9:9:172.9.0.11/32, version 124
Paths: (2 available, best #1, table ABC)
Advertised to update-groups:
Refresh Epoch 1
Local
9.9.0.5 (metric 11) from 9.9.0.7 (9.9.0.7)
Origin incomplete, metric 21, localpref 100, valid, internal, best
Extended Community: RT:9:9 OSPF DOMAIN ID:0x0005:0x0000006D0200
OSPF RT:0.0.0.0:2:0 OSPF ROUTER ID:172.9.0.5:0
Originator: 9.9.0.5, Cluster list: 9.9.0.7
mpls labels in/out 57/33
Refresh Epoch 1
109
172.9.113.11 from 172.9.113.11 (172.9.0.11)
Origin incomplete, metric 0, localpref 100, valid, external
mpls labels in/out 57/imp-null
HERE'S THE CONFIG OF PE1
address-family vpnv4
neighbor 9.9.0.7 activate
neighbor 9.9.0.7 send-community extended
exit-address-family
address-family ipv4 vrf ABC
no synchronization
network 172.9.0.3 mask 255.255.255.255
redistribute connected
neighbor 172.9.113.11 remote-as 109
neighbor 172.9.113.11 activate
neighbor 172.9.113.11 send-community both
neighbor 172.9.113.11 as-override
neighbor 172.9.113.11 send-label
exit-address-family
HERE'S THE CONFIG OF CE1:
router ospf 109
router-id 172.9.0.11
log-adjacency-changes
redistribute bgp 109 subnets tag 109
network 172.9.0.11 0.0.0.0 area 0
network 172.9.112.11 0.0.0.0 area 0
router bgp 109
bgp router-id 172.9.0.11
no bgp default ipv4-unicast
no bgp default route-target filter
neighbor 172.9.113.3 remote-as 9
address-family ipv4
no synchronization
redistribute ospf 109
neighbor 172.9.113.3 activate
neighbor 172.9.113.3 send-community both
neighbor 172.9.113.3 send-label
no auto-summary
exit-address-family
HERE'S THE CONFIG CE2
router ospf 109
router-id 172.9.0.12
network 172.9.0.12 0.0.0.0 area 0
network 172.9.112.12 0.0.0.0 area 0
network 172.9.125.12 0.0.0.0 area 0
LAST THE CONFIG PE2:
router ospf 109 vrf ABC
router-id 172.9.0.5
domain-tag 109
redistribute bgp 9 metric-type 1 subnets
network 172.9.0.5 0.0.0.0 area 0
network 172.9.125.5 0.0.0.0 area 0
router ospf 9
router-id 9.9.0.5
network 9.9.0.5 0.0.0.0 area 0
network 9.9.35.5 0.0.0.0 area 0
network 9.9.56.5 0.0.0.0 area 0
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
mpls traffic-eng multicast-intact
router bgp 9
bgp router-id 9.9.0.5
neighbor 9.9.0.7 remote-as 9
neighbor 9.9.0.7 update-source Loopback0
exit-address-family
no synchronization
network 172.9.0.5 mask 255.255.255.255
redistribute ospf 109 vrf ABC
exit-address-famil
Please let me know if need more info
Any help will be very much appreciated.
07-09-2013 01:22 AM
Hi Johnson,
I believe this is lab invironment and not production setup where you have to use BGP as PE-CE protocol on PE1 and OSPF as PE-CE protocol on PE2.
Now once you have two BGP route on PE1 VPN table, it will prefer route from PE2 over CE1 route because of lower AS-PATH attribute. To prefer CE1 route, you can set weight on PE1 router for neighbor 172.9.113.11 which will be locally significant.
Refresh Epoch 1
Local
Refresh Epoch 1
109 >>>>>>>>>>>>>>>>>>>>>
Akash
07-09-2013 09:36 AM
Correct!
I did change the weight and it is the best path
But the traffic still goes to PE1 - PE2 - CE2 - CE1 instead of PE1-CE1
See the outputs below.
PE1:
BGP routing table entry for 9:9:172.9.0.11/32, version 113
Paths: (2 available, best #2, table ABC)
Local
Extended Community: RT:9:9 OSPF DOMAIN ID:0x0005:0x0000000A0200
OSPF RT:0.0.0.0:2:0 OSPF ROUTER ID:172.9.0.5:512
mpls labels in/out 45/27
109
Origin incomplete, metric 0, localpref 100, weight 100, valid, external, best
mpls labels in/out 45/imp-null
TRACEROUTE:
P:
traceroute vrf ABC 172.9.0.11
9.9.23.3 [MPLS: Labels 18/27 Exp 0] 16 msec <======PE1
172.9.125.5 [MPLS: Label 27 Exp 0] 20 msec 20 msec 4 msec <======PE2
172.9.125.12 16 msec 48 msec 24 msec <======CE2
172.9.112.11 16 msec * 24 msec <======CE1
BGP(AS109) OSPF
| ospf/ibgp |
| AS 9 |
07-09-2013 09:40 AM
FROM RR ROUTER
P:
BGP routing table entry for 9:9:172.9.0.11/32, version 147
1 2
Local, (Received from a RR-client)
9.9.0.5 (metric 31) from 9.9.0.5 (9.9.0.5)
mpls labels in/out 51/27
109, (Received from a RR-client)
9.9.0.3 (metric 21) from 9.9.0.3 (9.9.0.3)
Origin incomplete, metric 0, localpref 100, valid, internal
mpls labels in/out 51/45
07-09-2013 11:39 PM
you can determine it by yourself if you go through BGP best path selection algorithm and compare each BGP attribute between two BGP routes.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Akash
