MPLS VPN Network Broken - Please Help
asaykao73
HI All,
I'm a bit lost as to why our mpls network is broken between our POPS. I don' know why I can't ping from PE2(lo99) to PE1(lo99). Because of this I can't establish a MP-BGP session between PE1 and PE2.
POP1[PE1 (lo99:172.16.99.13) -> P1] -> POP2[P2 -> PE2 (lo99: 172.16.99.4)]
PE2 can ping P1.
P2 can ping P1.
P2 and PE2 CAN NOT ping PE1.
VPN traffic seems to not get to P1 and go further.
PE2#ping 172.16.99.13
Sending 5, 100-byte ICMP Echos to 172.16.99.13, timeout is 2 seconds:
Success rate is 0 percent (0/5)
PE2#traceroute mpls ipv4 172.16.99.13 255.255.255.255
Tracing MPLS Label Switched Path to 172.16.99.13/32, timeout is 2 seconds
0 203.10.110.207 MRU 1500 [Labels: 3034 Exp: 0] <-- PE2
R 1 203.10.110.211 MRU 9000 [Labels: 8932 Exp: 0] 184 ms <-- packet reaches P2
. 2 * <-- this next hop should be P1 but packet not getting there
. 3 *
. 4 *
* It was working fine til we switched our P1>P2 link to switched ethernet. Our upstream
provider says everything is ok on their end and that jumbo frames are enabled within their
switched ethernet network.
* I've traced the labels from PE2 back to P2 > P1 > PE1 and they look ok.
PE2#sh mpls forwarding-table 172.16.99.13 32
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
617 3034 172.16.99.13/32 0 Gi0/0.11 203.10.110.211
P2#sh mpls forwarding-table 172.16.99.13 32
3034 8668 172.16.99.13/32 1582342 Gi4/0/1 203.17.96.97
P1#sh mpls forwarding-table 172.16.99.13 32
8668 Pop Label 172.16.99.13/32 158253163 Gi0/0.152 203.17.102.113
* Odd thing is that I can ping from PE1 > PE2 and PE1 > P2.
Just can't ping it the other way P2 > PE1 and PE2 > PE1.
PE1#ping 172.16.99.4
Sending 5, 100-byte ICMP Echos to 172.16.99.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
* I did a 'debug mpls packet' on P1 and can see labels being swapped ok (I think).
Nov 16 22:43:24.546 AEDT: MPLS turbo: Gi0/1: rx: Len 78 Stack {8668 6 255} - ipv4 data
Nov 16 22:43:25.606 AEDT: MPLS turbo: Gi0/0.152: rx: Len 86 Stack {7087 6 255} - ipv4 data
Nov 16 22:43:25.606 AEDT: MPLS turbo: Gi0/2: tx: Len 82 Stack {6039 6 254} - ipv4 data
Nov 16 22:43:26.878 AEDT: MPLS turbo: Gi0/0.152: rx: Len 86 Stack {7203 6 255} - ipv4 data
Nov 16 22:43:26.878 AEDT: MPLS turbo: Gi0/2: tx: Len 82 Stack {6628 6 254} - ipv4 data
Nov 16 22:43:27.358 AEDT: MPLS turbo: Gi0/0.152: rx: Len 86 Stack {7647 6 255} - ipv4 data
Nov 16 22:43:27.362 AEDT: MPLS turbo: Gi0/2: tx: Len 82 Stack {728 6 254} - ipv4 data
* Any ideas as to why all of a sudden I can not longer ping from P2 > PE1 and PE2 > PE1? It looks like a tranmission issue somewhere between P1 and P2 because I can't pass labels beyond P1 as seen from the traceroute mpls output above.
Please help...
Thanks.
Andy
Reza Sharifi
Hi Andy,
Do you have the same MTU configured on all your devices?
Reza
The main link from one POP to another is configured with MTU 9000 (see below). And I don't usually touch the MTU between the P and PE routers which would default to 1500.
It's always worked this way until we moved over to this new Switch Ethernet circuit for our backhaul from one POP to another. All of a sudden PE devices at POP2 can not ping PE devices at POP1 - BUT strange enough PE devices at POP1 can ping PE devices at POP2.
P1 Config
interface GigabitEthernet0/2
description Connection to P2
mtu 9000
bandwidth 150000
ip address 203.17.96.x 255.255.255.252
load-interval 30
media-type gbic
speed auto
duplex auto
negotiation auto
mpls ip
P2 Config
interface GigabitEthernet4/0/1
description Connection to P1
mtu 9000
bandwidth 150000
load-interval 30
negotiation auto
mpls ip
This has been resolved.
Turns out it was something within our Provider's network which does the backhaul for us that had some mac-access group configured on their switch which was blocking the PE's loopback from communicating with each other.
