MPLS VPN QoS on Ethernet Port
r.chung
We have a MPLS VPN network with 7206VXR as the PE switch. The 7206VXR has Ethernet Port for connecting to our switch for VoIP. I want to confirm whether can I enable QoS on the Ethernet or not for VoIP?
alexander.muhin
in most cases you should enable QoS for VoIP
Check the following links:
1. Enterprise QoS Solution Reference Network Design Guide Version 3.3 - MPLS VPN QoS Design
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
2. Next Generation Enterprise MPLS
VPN-Based MAN Design and
Implementation Guide - QoS for Critical Applications
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns241/c649/ccmigration_09186a008055edcf.pdf
Hope this helps,
Alexander
