MTU on Interface
olorunloba
Level 10
Level 10
Deploying MPLS VPNs, and thinking of increasing the MTU on my interfaces because of fragmentation. Who knows the maximum MTU the follwing hardwares can take.
NM2E-2W, NM2FE2W, WIC-1T, WIC-2T on 3600
PA-4E1G, PA-2FE, on VIP4-50 and FE2IP on RSP4 on 7507.
A link would be appreciated aslo
peter.fuchs
Community Member
As far as I know you need a MTU Size of about 1526
MTU + transport + ATOM + (MPLS Label)=
1500 + 18 + 0 + (4*2) = 1526
Link:
Jumbo/Giant Frame Support on Catalyst Switches
http://cisco.com/en/US/customer/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#topic1
best regards
Peter
Yes, but I need to know if the router would be able to pass these "jumbo frames", both on the ethernet and serial. I'm conccerned about the hardware limitation.
Was not able to find anything specific about supported MTU sizes for the interfaces you need.
So the best thing would be to try it.
tag-switching mtu 1526
BTW: this MTU size you realy need only on your P routers.
oettls
Level 3
Level 3
You shouldn't have problems with the serials (WIC-1T, WIC-2T). Don't know the exact limit but you can e.g. increase the tag mtu to 1524. (6 Labels == 24 bytes is the maximum recent IOS versions support). If you deploy AToM you might need even more (control word, ...).
PA-2FE should support 1510 bytes (L2 payload), guess the same applies for FE2IP.
hth,
Stefan
