Multicast for Hub and Spoke VPN
chintan-shah
Level 3
Level 3
Can we have Multicast VPN ( draft-rosen ) for Hub and Spoke based VPN ?
As of now we can not configure two VRF with same MDT Default and MDT Data MDT Multicast Group , which is required for HUB and SPOKE topology speically when I have both HUB  and SPOKE Site on same PE.
Is there any alternate solution ?
Chintan
15 Replies 15
Hi Chintan,
I have a very similar setup and was wondering what you were able to get working?
I have a hub and spoke setup with 2 hubs and many spokes across the MPLS cloud.
Several CE spokes interface with the same PE but use different VRFs.
Trying to assign the same MDT default group   [on the same PE router]   to more than one VRF fails -as you pointed out.
Do you have ANY updates???
THANKS
Frank
