OSPF PE-CE
zikalamc
Can someone please clarify for me the role played by OSPF in the backbone when ew are using OSPF between PE and CE. How is this different to when we're using a differenr PE-CE routing protocol?
A route with the "down bit" set, is it dropped by MP-BGP or by the bacbone OSPF?
Harold Ritter
The OSPF instance used by the backbone and the one used for the VRF are different and there is no interaction between the two.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thank you,
But does this mean that there's no requirement whatsoever to run OSPF in the backbone when using PE-CE OSPF (ISIS can be used). I was made to believe that this is a requirement.
Correct. You could run OSPF between the PE and CE and ISIS (or any other rp in the core).
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
routingboy
a route with the "down bit" set, will be dropped by the "vrf OSPF" of the PE
