Possible loop issue?
sullyjman12
Level 3
Level 3
We have an MPLS network that is managed by Verizon network between two different states (VA and TX).  We have are hosting Cognos in VA and some of the users over the MPLS network in TX are experiencing issues with accessing the site.   In VA I havent heard of any issues so im looking at the MPLS network.  Issues include delayed logins, delayed roaming the folders, it just hangs like its waiting for the server to respond.  I have seen this first hand at the office.
I was leaning towards a MTU issue but a wireshark caputure didnt show much of restransmission (back of my mind still wants to blame this).  Anything tips on what else I should look at with the wireshark I would be greatful.
Also I noticed some strange, when I do a traceroute from a client in TX to the Cognos server here in VA I get these results:
tracert 10.130.12.15
Tracing route to cognosserver [x.x.x.x]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  x.x.x.x  (TX)
  2    <1 ms    <1 ms    <1 ms  x.x.x.x  (TX)
  3     7 ms     7 ms     7 ms  x.x.x.x (MPLS network)
  4    43 ms    43 ms    43 ms  x.x.x.x (MPLS Network)
  5    45 ms    44 ms    45 ms  cognosserver [x.x.x.x]  (VA)
  6    47 ms    46 ms    44 ms  cognosserver [x.x.x.x] (VA)
Yes 5 and 6 is the same information hence why im scratching my head and maybe seeing a loop?
28 Replies 28
Ivan Krimmel
Level 9
Level 9
to find out whether the MTU size is indeed the culprit here, just issue a usual ping sweep with DF bit enabled.
This is all to the same host (from tx to cognos server)
ping servername -f -l 1472
Pinging servername [x.x.x.x] with 1472 bytes of data:
Reply from x.x.x.x: bytes=1472 time=47ms TTL=123
Reply from x.x.x.x: bytes=1472 time=46ms TTL=123
Ping statistics for 10.130.12.15:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 46ms, Maximum = 47ms, Average = 46ms
ping servername -f -l 1473
Pinging servername [x.x.x.x] with 1473 bytes of data:
Packet needs to be fragmented but DF set.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
ping servername -f -l 1500
Pinging servername [x.x.x.x] with 1500 bytes of data
Follow below steps.
1) Ask user from location other than TX say NY, to access VA's server, take feedback.
     --Also ask VA's user to access a server in NY.
2) From NY ask user to access a server in TX.
     -- Also ask TX user to access server in NY.
We would come to know whether there is issue in VA or TX or MPLS as a whole.
Ameya
Im confused by your statement and NY?  This is on an MPLS network provided by the ISP to connect our two remote offices together.  Nothing is accesible from the outside.
Okay,i assumed you hadusers at more than 2 locations .
NY was just an example.
Please take ISP in concurrence and post further updates.
Wish we could have helped.
Ameya
sullyjman12
Level 3
Level 3
Did a ping from an ubuntu box:
From VA to DC in TX
traceroute to x.x.x.x (x.x.x.x), 30 hops max, 60 byte packets
1  x.x.x.x (x.x.x.x)  1.017 ms  1.514 ms  2.018 ms
2  x.x.x.x (x.x.x.x)  6.521 ms  6.846 ms  6.948 ms
3  x.x.x.x (x.x.x.x)  8.734 ms  8.731 ms  8.725 ms
4  x.x.x.x(x.x.x.x)  50.054 ms  50.052 ms  50.142 ms
5  x.x.x.x (x.x.x.x)  53.599 ms  53.654 ms  53.834 ms
6  x.x.x.x (x.x.x.x)  50.920 ms  49.459 ms  49.434 ms Domain controller in TX
5 and 6 are dupes still
The traceroute hangs between 3 and 4 (like its waiting for the connection to wake up or maybe its just because of the jump)  Are these numbers bad?
Not really, this a normal latency.
Did you check with your ISP for info on MTU along the path from TX to VA?
Ameya
I am working on getting the circuit information so I can call and inquire!
sullyjman12
Level 3
Level 3
Interesting tidbit of testing, im messing around with iperf and here are some results I get:
I have an ubuntu box running in VA being the client and I have the domain controller (TX) the server.  Here are the results I get:
[1820] local x.x.x.x port 5001 connected with x.x.x.x port 36312
[ ID] Interval       Transfer     Bandwidth
[1820]  0.0-10.3 sec  7.88 MBytes  6.43 Mbits/sec [1820] local x.x.x.x port 5001 connected with x.x.x.xport 36312
If I make the Domain Controller the client and the Ubuntu box the server, here are the results I get:
[1868] local x.x.x.x port 3283 connected with x.x.x.x port 5001
[1868]  0.0-11.5 sec  15.6 MBytes  11.4 Mbits/sec [1868] local x.x.x.x port 3283 connected with x.x.x.x port 5001
I assume we should be getting the same amont of bandwidth both ways corrrect or at least speeds similar.  Correct?
Seems like im getting double the speeds in the TX and half in VA.
Yes, good piece of info.(How much is the BW promised by the ISP when you commissioned the link)
PLease test upload/download speeds with help of below tool.
First Download Ethernet throuput utility from below link.
http://www.softoxi.com/ethernet-throughput-utility.html
This is an awsome tool which i usually use to check WAN up/down link speeds.
Here is how it works.
topology:
[TX-client-PC]-----RTR1<-------WanLink---->RTR2---[VA-client-PC]
[Also You have to open port 5017 bidirectional on firewall if there is one in between.]
Now install one copy each of this utility on both mentioned PCs.
Open this tool on both PCs and do the below settings.
Step1: To check upload speed from TX to VA
TX-client-PC settings:
Scale: you have to specify the BW scale of your wan link.
In you case select 100Mb.
Connect : type IP of VA-client-PC
Now click "Run Sender" - basically this will start sending raw data on your Wan link.
VA-client-PC settings:
Scale: sameasabove
Connect : type IP of TX-client-PC
Now click "Run Listner" - this will start receivingraw data on your Wan link.(data which PC1 is sending above)
Step2: To check upload speed from VA to TX
Just check the sender and listners.
Ameya
I got a hold of Verizon and we are paying for a 45 Meg MPLS connection.
sullyjman12
Level 3
Level 3
Its amazing the stuff you find even when you  have been on the job for over 6 months, so I noticed the cubes have some kind of VPN
So I found out we have some kind of VPN module installed:
sh crypto engine brief
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
                     State:  Enabled
              Product Name:  Onboard-VPN
                FW Version:  01100200
              Time running:  46387 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0700
          Maximum SA index:  0700
        Maximum Flow index:  1400
      Maximum RSA key size:  2048
        crypto engine name:  Cisco VPN Software Implementation
        crypto engine type:  software
             serial number:  6C25F8CF
       crypto engine state:  installed
     crypto engine in slot:  N/A
DALLAS-CUBE#sh crypto engine brief
                     State:  Enabled
              Time running:  46649 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                  AES CNTR:  No
--More--
Slot 0:
        C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 7 ports
        Port adapter is analyzed
        Port adapter insertion time 12:58:56 ago
        Onboard VPN             : FW ver01100200
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC13304177
        Hardware Revision        : 1.4
        Top Assy. Part Number    : 800-23616-07
        Board Revision           : C0
        Deviation Number         : 102138
        Fab Version              : 05
I looked at the config and I dont see any configuration that tell me the VPN module is being used.  Is there anything in particular I need to look for?
! Last configuration change at 08:31:29 CDT Thu Sep 29 2011 by j
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname
boot-start-marker
boot system flash:c3845-adventerprisek9_ivs-mz.eng-sp-124-20.T2
boot-end-marker
card type t3 1
logging message-counter syslog
logging buffered 2000000
no logging rate-limit
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default stop-only group tacacs+
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
dot11 syslog
ip source-route
ip cef
ip domain name
ip name-server
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
rel1xx disable
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 8
rule 2 /^899\(.*\)/ /\1/
voice translation-rule 9
rule 2 /^999\(.*\)/ /\1/
voice translation-profile DIGITSTRIP-8
translate called 8
voice translation-profile DIGITSTRIP-9
translate called 9
crypto pki trustpoint TP-self-signed-1814427855
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1814427855
revocation-check none
rsakeypair TP-self-signed-1814427855
crypto pki trustpoint TP-self-signed-1589511804
subject-name cn=IOS-Self-Signed-Certificate-1589511804
rsakeypair TP-self-signed-1589511804
crypto pki certificate chain TP-self-signed-1814427855
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31383134 34323738 3535301E 170D3039 30383133 31373132
32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38313434
32373835 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D304 B6C1AA02 459E284F DE4921F3 8B7EE8C4 456F1C79 284AB9C2 4C20A300
DC2C2A21 3DCC5E26 9AD941E4 EAD17F8B 3234A152 4C573C4E 5BA55EA1 6FEB5694
F9C6ABCA 4BF27035 12A1FE03 540592E3 8FDA5044 08482306 D7151897 38F93CC9
A3B038C2 0F0B57B1 DEDDEE07 6B4DECE2 AE9C1F5C 22CEC30C 15F45C1E DF280AA8
B6730203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 1458A4CE 0E86D7A4 C06AC44E 7C39628B 943F5ED4
BA301D06 03551D0E 04160414 58A4CE0E 86D7A4C0 6AC44E7C 39628B94 3F5ED4BA
300D0609 2A864886 F70D0101 04050003 81810011 10CC4251 2455DEA8 56828713
8A85726A 2B3540C3 B407C86F 837E73B2 8ABAE691 2321C5A7 C2CEE8A8 24BA09D9
6AF46448 6C30B81B 7AD162D1 B4A2A666 DCAAE1C6 4106244D C22B46AE 6BDD0075
01AB7E2A 379569F7 2023F5EC 5FC205E3 B34C47D6 9E82CEC8 EEACB88E 8C8CCFD7
27D332FD E574EE23 43324720 6034223D 97FB5C
quit
crypto pki certificate chain TP-self-signed-1589511804
archive
log config
hidekeys
controller T3 1/0
clock source line
cablelength 200
ip ssh time-out 60
ip ssh version 2
description
ip address
load-interval 30
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0
description
ip address
ip flow ingress
ip flow egress
encapsulation ppp
no peer neighbor-route
dsu bandwidth 44210
router eigrp 100
redistribute bgp 65110 metric 10000 100 255 1 1500
passive-interface default
no passive-interface GigabitEthernet0/0
network 192.168.0.0 0.0.255.255
distance eigrp 90 10
no auto-summary
router bgp 65110
no synchronization
no bgp transport path-mtu-discovery
bgp log-neighbor-changes
network 0
network 0 mask 255.255.255.0
network 0 mask 255.255.255.252
aggregate-address summary-only
neighbor remote-as 65000
neighbor soft-reconfiguration inbound
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export source Serial1/0
ip flow-export version 9
ip flow-export destination
ip tacacs source-interface GigabitEthernet0/0
ip access-list standard SOLARWINDS
logging facility local0
logging source-interface GigabitEthernet0/0
tacacs-server host key 7 123E001607133F052325303B
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
call threshold global total-calls low 9 high 11
voice-port 0/0/0
voice-port 0/0/1
ccm-manager fallback-mgcp
ccm-manager redundant-host
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server
ccm-manager config
mgcp
mgcp call-agent 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp behavior g729-variants static-pt
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 5 identifier 2 priority 2 version 6.0
sccp ccm identifier 1 version 6.0
sccp ccm identifier 5 priority 1 version 6.0
sccp
sccp ccm group 10
bind interface GigabitEthernet0/0
associate ccm 5 priority 1
associate ccm 2 priority 2
associate profile 12 register
associate profile 14 register
associate profile 13 register
dspfarm profile 13 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 12 conference
description conference bridge
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 14 mtp
codec g711ulaw
maximum sessions hardware 4
sullyjman12
Level 3
Level 3
Also I noticed this:
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         xxxx   YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
Serial1/0                  xxxxxYES NVRAM  up                    up
SSLVPN-VIF0                unassigned      NO  unset  up                    up
So is the SSLVPN-VIFO being used?
Looks like its not being used:
SSLVPN-VIF0 is up, line protocol is up
  Hardware is SSLVPN_VIF
  Interface is unnumbered. Using address of SSLVPN-VIF0 (0.0.0.0)
  MTU 1406 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
