problem with arp NX-OS
Hello! I have a problem.
I have 2 leaf, which have connections to client 1,2. When client 1 try ping, it sends arp request, but it doesn't have reply. When I see dump, I see that leaf 1 replace arp-request on vxlan, but it doesn't send reply to client 1. I don't understand this situation.
My config, and debug information
hostname leaf3
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature interface-vlan
feature vn-segment-vlan-based
feature lacp
feature lldp
feature nv overlay
no password strength-check
role network-admin
ip domain-lookup
copp profile strict
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
fabric forwarding anycast-gateway-mac 0000.2222.3333
vlan 1,201-202,999
vlan 201
name cli1_tanant1
vn-segment 50201
vlan 202
name cli2_tanant1
vn-segment 50202
vlan 999
name L3_VNI
vn-segment 50999
route-map permitall permit 10
vrf context Tenant-1
vni 50999
rd auto
address-family ipv4 unicast
route-target both auto
route-target both auto evpn
vrf context management
interface Vlan1
interface Vlan201
no shutdown
vrf member Tenant-1
no ip redirects
ip address 10.0.201.254/24
fabric forwarding mode anycast-gateway
interface Vlan202
no shutdown
vrf member Tenant-1
no ip redirects
ip address 10.0.202.254/24
interface Vlan999
no shutdown
vrf member Tenant-1
ip forward
interface nve1
no shutdown
host-reachability protocol bgp
source-interface loopback1
member vni 201
member vni 50201
ingress-replication protocol bgp
member vni 50202
member vni 50999 associate-vrf
interface Ethernet1/1
no switchport
mtu 8000
port-type fabric
medium p2p
no ip redirects
ip unnumbered loopback0
no ipv6 redirects
ip ospf network point-to-point
ip router ospf 1 area 0.0.0.0
no shutdown
interface Ethernet1/2
no switchport
mtu 8000
port-type fabric
medium p2p
no ip redirects
no ipv6 redirects
no shutdown
interface Ethernet1/3
switchport access vlan 201
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface loopback0
description routerID underlay
ip address 10.10.10.3/32
interface loopback1
description nve
ip address 10.200.200.3/32
icam monitor scale
line console
line vty
router ospf 1
router-id 10.10.10.3
router bgp 65400
address-family l2vpn evpn
retain route-target all
neighbor 10.10.100.6
remote-as 65400
update-source loopback0
send-community
send-community extended
neighbor 10.10.100.7
remote-as 65400
send-community
vrf Tenant-1
redistribute direct route-map permitall
evpn
vni 50201 l2
rd auto
route-target import auto
route-target export auto
vni 50202 l2
rd auto
leaf3# show bgp l2vpn evpn
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 10.10.10.1:3
*>i[5]:[0]:[0]:[24]:[10.0.201.0]/224
10.200.200.254 0 100 0 ?
*>i[5]:[0]:[0]:[24]:[10.0.202.0]/224
Route Distinguisher: 10.10.10.1:32968
*>i[2]:[0]:[0]:[48]:[0050.7966.6800]:[0]:[0.0.0.0]/216
10.200.200.1 100 0 i
*>i[2]:[0]:[0]:[48]:[0c5a.0000.1b08]:[0]:[0.0.0.0]/216
10.200.200.254 100 0 i
*>i[2]:[0]:[0]:[48]:[0050.7966.6800]:[32]:[10.0.201.1]/272
*>i[3]:[0]:[32]:[10.200.200.254]/88
Route Distinguisher: 10.10.10.1:32969
Route Distinguisher: 10.10.10.3:32968 (L2VNI 50201)
*>l[2]:[0]:[0]:[48]:[0050.7966.6801]:[0]:[0.0.0.0]/216
10.200.200.3 100 32768 i
*>l[2]:[0]:[0]:[48]:[0050.7966.6801]:[32]:[10.0.201.2]/272
*>l[3]:[0]:[32]:[10.200.200.3]/88
Route Distinguisher: 10.10.10.3:32969 (L2VNI 50202)
Route Distinguisher: 10.10.10.3:3 (L3VNI 50999)
* i[5]:[0]:[0]:[24]:[10.0.201.0]/224
*>l 10.200.200.3 0 100 32768 ?
* i[5]:[0]:[0]:[24]:[10.0.202.0]/224
leaf3# show l2route evpn mac all
201 0050.7966.6800 BGP SplRcv 0 10.200.200.1 (Label:
50201)
201 0050.7966.6801 Local L, 0 Eth1/4
999 0200.0ac8.c8fe VXLAN Rmac 0 10.200.200.254
999 0c5a.0000.1b08 VXLAN Rmac 0 10.200.200.1
vni 50201 l2
rd auto
suppress-arp <<- add this to both leaf and check
MHM
17 Replies 17
Enes Simnica
gDay @kirill-pototskiy98The problem here is that ur NVE configuration has both member vni 201 and member vni 50201. Now, since VNI 201 is not actually mapped to VLAN 201, that extra line causes confusion in the control-plane. What u should have is only the 50201/50202 VNIs with ingress replication, mapped consistently to VLANs 201 and 202 across both leaves. Also make sure ur anycast gateway MAC and SVI IPs are identical on both leaves and that ARP suppression is enabled if needed. So my Cisco friend, in short, remove the stray VNI 201 from the NVE, double-check that VLAN-to-VNI mappings match on both leaves, and confirm your NVE peers and VNIs are up,  once those are corrected, the ARP replies will start working.../
hope it helps and PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
I send debug information message below
why ARP need here
BGP advertise the MAC-IP so no need for ARP
ping from host to host and check
MHM
ping don't work, because cli1 doesn't have mac addr cli2
check below my comment please share info I need
MHM
leaf3# show run | sec vni
vni 50999
member vni 50201
member vni 50202
vni 50201 l2
rd auto
vni 50202 l2
rd auto
leaf3# show run | sec vlan
limit-resource vlan minimum 16 maximum 4094
vlan 1,201-202,999
vlan 201
name cli1_tanant1
vn-segment 50201
vlan 202
name cli2_tanant1
vn-segment 50202
vlan 999
name L3_VNI
vn-segment 50999
leaf3# show nve peers
Interface Peer-IP State LearnType Uptime Route
r-Mac
nve1 10.200.200.1 Up CP 02:45:07 0c5a.
0000.1b08
nve1 10.200.200.254 Up CP 05:05:56 0200.
0ac8.c8fe
leaf3# show nve vni
Codes: CP - Control Plane DP - Data Plane
UC - Unconfigured SA - Suppress ARP
S-ND - Suppress ND
SU - Suppress Unknown Unicast
Xconn - Crossconnect
MS-IR - Multisite Ingress Replication
HYB - Hybrid IRB mode
Interface VNI Multicast-group State Mode Type [BD/VRF] Flags
nve1 50201 UnicastBGP Up CP L2 [201]
nve1 50202 UnicastBGP Up CP L2 [202]
nve1 50999 n/a Up CP L3 [Tenant-1]
leaf3# show ip arp suppression topo-info
ARP L2RIB Topology information
Topo-id ARP-suppression mode(HMM SDB value)
201 ARP Suppression Disabled (ARP Suppression Disabled)
202 ARP Suppression Disabled (ARP Suppression Disabled)
!Command: show running-config interface Vlan201
!Running configuration last done at: Thu Aug 21 06:40:50 2025
!Time: Thu Aug 21 11:21:28 2025
version 10.3(1) Bios:version
interface Vlan201
no shutdown
vrf member Tenant-1
no ip redirects
no ipv6 redirects
leaf1#
leaf1# show run | sec evpn
nv overlay evpn
send-community
send-community
evpn
vni 50201 l2
rd auto
vni 50202 l2
rd auto
leaf1# show run | sec vni
name L3-vni-tenant1
vni 50999
member vni 50201
member vni 50202
vni 50201 l2
rd auto
vni 50202 l2
rd auto
leaf1# show run | sec vlan
vlan 1,99,201-202,999
vlan 99
name svi
vlan 201
name cli1
vn-segment 50201
vlan 202
name cli2_tenant-1
vn-segment 50202
vlan 999
name L3-vni-tenant1
vn-segment 50999
leaf1# show nve peers
r-Mac
nve1 10.200.200.3 Up CP 05:06:02 0c91.
0000.1b08
leaf1# show nve vni
S-ND - Suppress ND
leaf1#
issue is solved or not ?
MHM
no, sorry
50201)
above for leaf3 what about leaf1 what you see ?
MHM
Network Next Hop Metric LocPrf Weight PathRoute Distinguisher: 10.10.10.1:32968 (L2VNI 50201)
*>l[2]:[0]:[0]:[48]:[0050.7966.6800]:[0]:[0.0.0.0]/216 10.200.200.1 100 32768 i
*>i[2]:[0]:[0]:[48]:[0050.7966.6801]:[0]:[0.0.0.0]/216 10.200.200.3 100 0 i
*>l[2]:[0]:[0]:[48]:[0c5a.0000.1b08]:[0]:[0.0.0.0]/216 10.200.200.254 100 32768 i
*>l[2]:[0]:[0]:[48]:[0050.7966.6800]:[32]:[10.0.201.1]/272 10.200.200.1 100 32768 i
*>i[2]:[0]:[0]:[48]:[0050.7966.6801]:[32]:[10.0.201.2]/272 10.200.200.3 100 0 i
*>i[3]:[0]:[32]:[10.200.200.3]/88 10.200.200.3 100 0 i
*>l[3]:[0]:[32]:[10.200.200.254]/88 10.200.200.254 100 32768 i
Route Distinguisher: 10.10.10.1:32969 (L2VNI 50202)
*>i[5]:[0]:[0]:[24]:[10.0.201.0]/224 10.200.200.3 0 100 0 ?
*>i[5]:[0]:[0]:[24]:[10.0.202.0]/224 10.200.200.3 0 100 0 ?
Route Distinguisher: 10.10.10.1:3 (L3VNI 50999)
*>l[5]:[0]:[0]:[24]:[10.0.201.0]/224 10.200.200.254 0 100 32768 ?
* i 10.200.200.3 0 100 0 ?*>l[5]:[0]:[0]:[24]:[10.0.202.0]/224
10.200.200.254 0 100 32768 ?* i 10.200.200.3 0 100 0 ?
show l2route evpn mac all <<- this please
MHM
message below
leaf-1
201 0050.7966.6800 Local L,Orp 0 Eth1/3
201 0050.7966.6801 BGP SplRcv 0 10.200.200.3 (Label:50201)
201 0c5a.0000.1b08 VXLAN Stt,Nho, 0 10.200.200.254
202 0c5a.0000.1b08 VXLAN Stt,Nho, 0 10.200.200.254
999 0c5a.0000.1b08 VXLAN Stt,Nho, 0 10.200.200.254
999 0c91.0000.1b08 VXLAN Rmac 0 10.200.200.3
leaf3
50201)
Leaf1
201 0050.7966.6800 Local L,Orp 0 Eth1/3 <<- this LOCAL i.e. host direct connect to this port
201 0050.7966.6801 BGP SplRcv 0 10.200.200.3 (Label:50201) <<- this learn via BGP
Leaf3
201 0050.7966.6800 BGP SplRcv 0 10.200.200.1 (Label:50201)
So control plane is OK and it advertise MAC-IP
