QoS in MPLS network - Backbone circuit
werner.legrange
Refer to network diagram. Given the scenario where you have one MPLS client connecting (x3) 2Meg last mile circuits onto a PE and the STM1 Backbone circuit terminating on the same PE router. PE/P collapsed model.
Requirement:
Client should be able to utilize the full 2meg capacity on each of their last mile circuits for inter branch communication on the same PE router.
On the backbone the client's traffic should be limited to 4Megs in total.
What is the best QoS model to implement with the given topology?
Will it maybe be better to change the network topology/add more routers to accomplish the requirement above?
Werner
0 Replies 0
