Question on LFA
chintan-shah
Level 3
Level 3
I have been doing various test for LFA on PRP2 IOS-XR 4.0.3.
It seems that Cisco do not consider Node protection as a option while computing LFA and finding alternate backup path.
Consider below topology :
All routers are in ISIS L1 area and primary route from Node A to Node C loopback is via Node B . During testt, I am seeing LFA from Node A is again via Node B via second link between A and B (based on IGP metric).I would have expected the backup path would be from A to C Direct link ( i.e. avoid Node B in backup path in case it fails , hence node protection) but It looks cisco don’t care about node protection.
I have configured per-prefix feature.
Can some one clarify if it is expected and if yes, Is there any way to consider node protection during LFA to install backup path.
Chintan
Nagendra Kumar Nainar
Hi Chintan,
To my knowledge, it is working as expected. As you can see in RFC 5286, Section 3.2, for node protection, alternate link should not go via the node to be protected.
For an alternate next-hop N to protect against node failure of a
   primary neighbor E for destination D, N must be loop-free with
   respect to both E and D.  In other words, N's path to D must not go
   through E.
In your case, by increasing the metric from 20 to 41 or more should provide you node protection.
HTH,
Nagendra
Hi Nagendra,
Thanks for pointing RFC section. it looks like it doesn't meet inequality 3 hence can't have node protection.
So if i go with below topology , based on this section 3.2, here also i should not expect node protection.
Right ?
Chintan
Hi Chintan,
Yes. The alternate path from NodeA to NodeC is again via Node B (A->D->B->C). So Node protection is not possible.
HTH,
Nagendra
