re-initialize MPLS
jahilnt
Community Member
I've ran into a problem (again) which I have not been able to solve - I
asume it might be a problem in IOS, but I need to find some solution
(other than the one I have currently) ...
I have 4 backbone routers talking MPLS to each other. This works fine
for days and months ;), so I believe the basics are correctly
configured. Looks something like this:
A ------- B ------ C ------ D
50m WAN POS LAN
Now, if e.g. POS link goes down (either by failure or for administrative
reasons), then comes back up, everything might be fine. MPLS routing
will still work, I can still reach VRFs behind D from A. Anyway,
sometimes, the MPLS path from A to D is disrupted by the POS downtime
and will not recover. I have had to reboot B before to get it to work
again, today I had to reboot C and D to recover. Also, today the "show
mpls ldp nei" on C and D didn't show the other side. Trying to
re-initialize MPLS by removing it from the FE/GE ports on both C and D
didn't help ... And it's not that I didn't wait long enough - on one
occasion, MPLS was down for several hours (until reboot) ...
Is there a way to re-initialize MPLS on a router without booting it?
IOS versions in use:
A 12.0(25)S1
B 12.2(13)T9
C 12.1(3a)E5
D 12.3(3)B1
Any idea?
If the "show mpls ldp nei" doesn't show anything then you propably start from there. Next time it happens, can you also perform a "show mpls ldp dis" on both routers.
