routing ASA for MPLS connection
Doug Charboneau
I am having some trouble routing an existing MPLS connection. The MPLS is managed by our ISP and is working. I am trying to put in a new 5512 asa and I have added a static route "route inside mpls_remotenetwork mpls_gateway" this route works on my Sonicwall currently but not on my new cisco. The only other route is the default gateway and directly connected interfaces.
I am not sure if I am missing something.
7 Replies 7
blau grana
Level 7
Level 7
Hello Doug,
This is maybe stupid question, but I ask anyway
Is interface toward ISP device inside interface? That does not make much sense to me, I would expect it to be an outside interface. Is there any reason for this?
-> I thought that amybe you just made mistake and it is outside interface.
If it is really inside interface, what do you mean by "it does not work"? After configuration do you see this route in routing table and configuration, any error message?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
So you think that I might need to issue the intra network command. I believe inter is issued when enabling same security.
Doug Charboneau
The MPLS connection has a connection to my switch directly inside my network, with my current Sonicwall setup I simply add a static default route for any address on the remote network use the MPLS local address. With the cisco asa I add the above route and I can ping addresses on the other end but I cannot access any systems. ie pcs or firewall at the other end.
Hello Doug,
Some sketch of your topology would help, now we can only guess what is where.
- the MPLS connection has a connection to my switch directly inside my network
- with my current Sonicwall setup I simply add a static default route for any address on the remote network use the MPLS local address
- with the cisco asa I add the above route and I can ping addresses on the other end but I cannot access any systems. ie pcs or firewall at the other end.
Do you want to replace Sonicwall with new ASA, or do you want to use them both?
What device is on other end of MPLS connection?
Does this device permit traffic from new ASA?
What is configuration of ASA? Maybe it is not properly configured.
As I asked earlier, do you see static route in routing table after configuration or is it rejected for some reason?
As I said we can only guess where could be problem, so please provide some more additional info.
Best Regards
Doug Charboneau
Sorry I was not more thurough in my original post. Currently we have a sonicwall firewall in place. the Sonicwall (UTM) does handle our internal routing as well as ips system. We have a vendor suplied cisco router that supplies our internet as well as an MPLS connection to another location. The internet connection is connected to our outside port of the Sonicwall. The MPLS connection goes straight into our switch, which would put it connected to our inside port. Currently we have just needed to add a static route to our Sonicwall and traffic flows through the MPLS connection to the remote end. I am trying to replace the Sonicwall with a Cisco ASA 5512. Everything comes up fine except I cannot access the remote network. I have added in the static route to the MPLS but that has not helped. The odd part is I can ping the devices at the other end, I just cannot access them (rdp, https). I have enabled same security inter and intra. I thought that intra would take care of my issue but it did not. Am I missing an access rule that needs to be in place?
Thanks again for any help provided.
inside network 192.169.1.0\24
MPLS network 192.169.2.0\24
current static route entered
route inside 192.169.2.0 255.255.255.0 192.169.1.253 1
Doug Charboneau
I have read some today about hairpinning an interface. I cannot do it until tonight but I wounder if I add a static nat inside, inside statement for the remote network if it will work.
Has any one else ever delt with hairpinning on an asa?
Hi Doug,
What version of code are you running on your ASA?
Do you have an access list on the inside interface of your ASA?
It may be worth asking thisover in the security/firewalling support forum. I've had some problems with hairpinning on ASA's, and it depend on code versions as this feature has changed over time.
