Same serial number for two different 7600 clock module
dinesh.kumarvinganam1
Community Member
Hi Guys,
   I am seeing same serial number for two different clock modules of 7600. Though both are in same chassis, is it possible? Or is it due to some s/w bug we are seeing this (display issue)?
V Dinesh Kumar
Vinit Jain
Hello Dinesh
Its highly unlikely that two modules have the same S/N but at the same time i dont suspect that this could be a software bug. Could you please answer the below:
- Can you please share the show version, show module and show inventory in a file
- When was the 2nd module added? Were there any recent changes done on the router like HW swap, HW replacement, etc?
I can cross check based on the s/w version if we have seen similar behavior in the past.
Please share the above requested info.
Vinit
--Vinit
