Same vllans on 2 sites
amitbatra
Hi all,
well i have 2 sites using vlan 1-10 on both sites. there are hosts in all vlans wants to communicate as if the switches are directlly connected. but these 2 sites are connected via MPLS backbone.. can anyone please advice me what needs to be configured .
regards
amit
hadbou
Level 5
Level 5
('MPLS cloud' got me clouded). Then what you need is VLAN-VLAN local switching, which I guess should be coming in for 7200/7500 in the 12.0(30)S/31S timeframe.
pbenin
You need a VC Ethernet-O-MPLS with VLANs transport.
I am trying to do the same briding vlans over EoMPLS between 2 6500. The MPLS will terminate directly my 6500's with WS-SUP720-3Brunnning IOS s72033-ipservicesk9_wan-mz.122-18.SXF10a.bin. Will that be ok?
