Segment Routing Maximum SID Depth (MSD)
muthu.arul
Visitor
I've a couple of questions on Segment Routing Maximum SID Depth (MSD):
  • Is there a command to configure and view MSD on ASR9K / CRS?
  • If I have a SR-TE tunnel that uses SIDs up to MSD and an L3VPN service using 2 more labels (a VPN label + a BGP-LU label) that uses this SR-TE tunnel, what would the behavior be?
Muthu
Leonir Hoxha
I don't think you are able to configure the MSD. I believe it is hard-coded into the Hardware.
Sudhir Kumar
MSD depends on the hardware platform and it can vary from platform to platform.
Sudhir Kumar
