SoO and EIGRP for PE-CE, again
apasquino
In a MPLS L3VPN a have a site where two PEs and two CEsare sitting on a LAN where EIGRP runs.
I've set up SoO (same community applied on both PEs)
PE1
interface Vlan970
vrf forwarding ap1
ip vrf sitemap SoO
ip address 61.2.100.7 255.255.255.0
router bgp 2
address-family ipv4 vrf ap1
  redistribute eigrp 2002
exit-address-family
router eigrp 2008
  redistribute bgp 2 metric 10000 10 1 255 1500
  network 61.2.100.0 0.0.0.255
  autonomous-system 2002
exit-address-family
PE2
interface Vlan970
vrf forwarding ap1
ip vrf sitemap SoO
ip address 61.2.100.8 255.255.255.0
router bgp 2
exit-address-family
router eigrp 2008
exit-address-family
Here's what I get as output of sh ip ro vrf ap1:
PE1
C        61.2.100.0/24 is directly connected, Vlan970
L        61.2.100.7/32 is directly connected, Vlan970
D        61.2.103.0/24 [90/130816] via 61.2.100.2, 00:24:01, Vlan970          OK: behind local CE, known via EIGRP internal
B        61.2.104.0/24 [200/171] via 50.50.0.16, 02:28:40                           OK: remote site, known via remote PE
PE2
L        61.2.100.8/32 is directly connected, Vlan970
D        61.2.103.0/24 [90/130816] via 61.2.100.2, 00:25:22, Vlan970          OK: behind local CE, known via EIGRP internal
D EX     61.2.104.0/24 [170/258816] via 61.2.100.7, 00:25:07, Vlan970     KO: I thought this route would come from iBGP...
I'm sure I'm missing something real simple, hope you can advie me.
Andrea
blau grana
Level 7
Level 7
hello,
can you post output from
PE2# sh ip bgp vpnv4 vrf ap1
PE2# sh ip bgp vpnv4 vrf ap1 rib-failure
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Blau Grana,
Here you are:
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 11:11 (default for vrf ap1)
* i 61.2.100.0/24  50.50.0.7                0    100      0 ?
*>                   0.0.0.0                  0         32768 ?
* i 61.2.103.0/24  50.50.0.7           130816    100      0 ?
*>                   61.2.100.2        130816         32768 ?
*>  61.2.104.0/24  161.27.100.7        258816         32768 ?
* i                  50.50.0.16             171    100      0 ?
  Network            Next Hop                      RIB-failure   RIB-NH Matches
Best Regards
Andrea
Are you sure you gave us correct info? it seems to me that two outputs, from routing and bgp table do not correlate. can you check that please and also include some sketch of topology.
Best Regards
here you are with the layout, the 50.50.0.16 is the BGP loopback of the remote PE.
AP
